Rims the same size
Old May 11, 2009 | 10:19 PM
onevettenut's Avatar
onevettenut
Default Rims the same size
Has anyone put 19" rims on all four? What kind of clearance problems if any with the C5
Old May 11, 2009 | 10:27 PM
STL94LT1's Avatar
STL94LT1
I'm running 19's up front and 20's out back without any clearance problems.
Old May 11, 2009 | 10:31 PM
De_Vette's Avatar
De_Vette
St. Jude Donor '09-'10-'11-'12
Clearance isn't a problem if you mount the correct tire on the 19" rim. The overall diameter should be close to the stock diameter at least this is how I understand it.
http://www.miata.net/garage/tirecalcold.html
Old May 11, 2009 | 10:36 PM
SS~7's Avatar
SS~7
You are correct ...I have a 19/20 combo now. I've had a 19/19 combo on my slammed vert ...no issues if you run the proper offset wheel and correct size tires ...
To Rims the same size
