clutch life
Old May 13, 2009 | 01:20 PM
firstvette99's Avatar
firstvette99
Default clutch life
how long do stock clutches last.looking at a 2000 with about70000.just want a ballpark number.
thanks
Old May 13, 2009 | 02:29 PM
firstvette99
ttt
Old May 13, 2009 | 02:38 PM
Some members have over 100K with the stock clutch. It's hard to say how long one will last because driving styles vary so much.
Old May 13, 2009 | 02:53 PM
Fast Cop's Avatar
Fast Cop
My 00 vert 6 speed has 74,000 miles and the clutch is still going strong.
Old May 13, 2009 | 03:10 PM
VetterGetIt's Avatar
VetterGetIt
156k miles on my original clutch and did a small burnout yesterday!
Old May 13, 2009 | 03:46 PM
Oldvetter's Avatar
Oldvetter
119,000 miles on my original 1998 Clutch and no problems (knock on wood) !
Old May 13, 2009 | 04:07 PM
SearayC5's Avatar
SearayC5
Driving style is the factor, but I know that I pulled my C5Z clutch out at 55 thousand and it had well over half life. You should be fine because I know many have over 100 k on theirs. If you are really worried you can have them put it on a lift and check the disc thickness by removing the bellhousing inspection cover. When on a lift it only requires 6 bolts or so to be removed.
Old May 13, 2009 | 07:49 PM
USACorvette's Avatar
USACorvette
mine went at 110k it was slipping bad at that point, still drivable but no power
and btw its a very costly fix I think I spent 1500 on clutch and labor and a few other maint items at the same time
Old May 13, 2009 | 08:20 PM
tdahl's Avatar
tdahl
thanks
On his 2000 frc, my brother has 160K on original clutch (old guy) but it is hard to get into gear at times...... I put a new one on my 99 frc at 90K....... big differance.........no longer a struggle at times, and I dont smell clutch when I get home............ its a crap shoot honestly when to replace....... save you money to get it done...... I did the LS7 upgrade and love it......
Old May 13, 2009 | 10:38 PM
axlebreaker's Avatar
axlebreaker
115k on mine and I drive it like I stole it
To clutch life
