Time guesses for 1/4 mile?
Old May 14, 2009 | 08:29 PM
83Camaro's Avatar
83Camaro
Default Time guesses for 1/4 mile?
Theres a test and tune here locally they finally opened the military base up since 9/11 to drag racing. I have a 1999 Coupe with 84k miles and its an A4 with black wing intake and corsa? cat back, and also bald rear run flats. Looking for any guesses on what i might run and shoot for time wise for the 1/4. Thanks
Old May 14, 2009 | 08:39 PM
happa's Avatar
happa
Id guess being an Auto and bald tires around 13.2-13.0. Good Luck and let us know what you do run
Old May 14, 2009 | 08:45 PM
vettandtyphoon1's Avatar
vettandtyphoon1
man.. don't be expecting too great of times.
the a4's with 2.73's really are slouche's.
i'm gonna go 14.0-14.1 realistically ..
seen many a4 coupes do that around here. without bald tires
Old May 14, 2009 | 08:54 PM
Ryan L's Avatar
Ryan L
I'd rather have an 83 Camaro.
Old May 14, 2009 | 09:07 PM
motogib1's Avatar
motogib1
Get a street tune and I'd guess low 13s.
Old May 14, 2009 | 09:48 PM
83Camaro's Avatar
83Camaro
I have the 3:15s and there arent any tuners in alaska.
Old May 16, 2009 | 08:07 PM
83Camaro's Avatar
83Camaro
My best time out of 3 runs on a slick track, weighing 270lbs myself, and bald rear emt mud and snow tires was a 13.7
Old May 16, 2009 | 08:12 PM
black98c5's Avatar
black98c5
Get a 3200 stall and some Nittos 555R's at least, and you'll be 12.8-13.2 all day!!!
Old May 17, 2009 | 01:02 AM
Mister Peebody's Avatar
Mister Peebody
From: Ok! So you don't believe in conspiracies, but will you acknowledge the possibility of there being coordinated activities in secret places? Texas
I was gonna guess 13.5 at about 103. That is what I ran inmy '98 'vert with a honker, B&B cat back, 3.15 rear gear, and 295/35/19 on the rear. Don't be disappointed that your stock car won't go 12.8 at 108. All of us can't be that fortunate. If we are to believe everything we read, there are many stock LS1 vettes here that out 1/4 my LS6 vette. Your car appears to perform on par with other "normal" basically stock vettes. Enjoy it!
Old May 17, 2009 | 01:43 AM
DuronClocker's Avatar
DuronClocker
FWIW I went 13.24@106 (2.03 60') with nothing but a K&N air filter, non-RFT Toyo tires, and some slightly quicker shifts via HP Tuners (set desired shift times to .250sec).
Put a drag radial on it and did the zip tie mod and ended up with a 13.15@106 (1.99 60'). I'd say the drag radials didn't do anything for me based on the 60'
Ran two passes with a 107.3MPH. DA was 900'
1997 A4/2.73s, 117k miles (trans replaced with GM reman at 100k).. lowered on Bilstein Sports.
Old May 17, 2009 | 08:53 AM
TopFuelTim's Avatar
TopFuelTim
prolly 13.70s to low 14s, depending on traction.
My .02 worth.
Tim Glover
Old May 17, 2009 | 10:00 AM
83Camaro's Avatar
83Camaro
THe 13.7 run was with traction control on, the other 2 were slower with it off, i got my launchign down great but hooking up after that was an issue and i couldnt get traction.
Old May 17, 2009 | 10:07 AM
tail_lights's Avatar
tail_lights
Pretty much what I would guess
Old May 17, 2009 | 11:04 AM
vettandtyphoon1
i myself always ran faster with the traction control off. it just always bogged to bad for me to leave it on.
you had some pretty good times there buddy 13.1 with what mods you had. some cars are "freaks" from the factory.
my buddy has a 01 z28.. he switched his ls6 intake for a polished holley wiend, cut the muffler out of the car, k &n air filter, and a tune.
he dyno'd at 360 rwhp and 350 ft lbs. CRAZY for that car. and he's a a4 with 2.73's
Old May 17, 2009 | 11:06 AM
vettandtyphoon1
fwiw every 1/10 off of your 60 ' is worth about 3/10's at the 1/4 mile
Old May 17, 2009 | 12:19 PM
83Camaro's Avatar
83Camaro
I tried the 1st 2 with traction control off, and my bald tires didnt help. I ran a 14.0 first run, with a horrible .7 reaction, and then the 2nd run i had a .3 reaction but i lost traction out of the gate and it cost me big time at a 14.9
Old May 17, 2009 | 12:25 PM
Vega$Vette's Avatar
Vega$Vette
Reaction time has nothing to do with your ET
Old May 17, 2009 | 12:36 PM
83Camaro's Avatar
83Camaro
Oh well, it matters to me when im trying to beat the other person.
Old May 17, 2009 | 12:41 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
13.08@102 mph
To Time guesses for 1/4 mile?
