[Z06] Escort 8500
I've seen several posts on this subject, both indicating the connections are in different places. One indicated that there were hardwire points behind the passenger side kick panels, the other indicated there were some under the passenger side footwell carpeting.
I don't want to dismantel the car to find the connection points.
Where should I start looking? :confused:
2002 Black/Black ZO6
I understand it is UNDER the passengers FEET............( carpet will have to come up)
Should be a color coded accessorie tagged for just such a deal........ :yesnod:
black = ground
orange = 12v constant
yellow = 12v switched (active when ignition is turned on)
hook the wires up to the black and yellow,,,,,,,,replace the footwell panel and fold back over the floormat,,,,,,,,then youre all set
imp.
You gotta get low enough to miss the window tinting or I guess there could be a problem.
