Inserts and Z06 screens
Old May 19, 2009 | 10:25 PM
Robert 2000's Avatar
Robert 2000
Default Inserts and Z06 screens
Hi guys I am ordering inserts for the Corvette on the bumpers soon and was wondering if it matters what ones to get???I am looking to get black btw. I looked on corvette america and 15 dollars or so each seemed like it was to cheap to be any good... and with the Z06 screens where should I order them and do they come with what I need to mount them and how are they mounted...I know there are different options???
Thanks in Advance
Rob
Sorry for the newb Questions
Old May 20, 2009 | 08:31 AM
Robert 2000
Bump....Anyone??
Old May 20, 2009 | 08:35 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Hey Rob,
I don't have any black inserts, but RaceMesh are the best screens on the market, IMHO
http://www.customcorvetteaccessories...shgrilles.html
Peace
Chip
__________________
..................Click for
Old May 20, 2009 | 09:37 AM
Robert 2000
Awsome thanks how are they held in place?? and Standard stainless would be like the oem Z06 right??
thanks
Rob
Old May 20, 2009 | 09:48 AM
CCA Corvette Parts
thanks
Rob
Rob,
The STD SS is like the OEM but much thicker grade.
The Z06 Screens come with 2 sided tape, but I recommend removing it and using velcro instead (so you can remove at a later date if you want to clean)
Please be advised that these are made to order and take 4 weeks, but it is well worth the wait.
You may want to check with RPI designs for the inserts...
Peace
Chip
Old May 20, 2009 | 09:56 AM
Robert 2000
Ok thanks I am guessing you just take off the double sided tape and replace with velcro. Sounds good and I ll wait to do it right should be putting in my order soon
Old May 20, 2009 | 10:01 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
I bought a complete set of the RaceMesh, 8 pieces in black powdercoat, but haven't installed them yet. They are very "meaty" and should last indefinitely. The preferred method of installation is to silicone them into place from the inside, so no edges are exposed. The front fog light grilles come with weather stripping around them for a finished look, push into place and are held with a couple tie wraps.
I prefer the black version as I want these to be functional without being the center of attention - a finishing touch that usually goes unnoticed until closer inspection.
Old May 20, 2009 | 01:17 PM
Robert 2000
Awsome yea I am going to get black not the whole set though and idk if i can get to the backside with the vararam...
Old May 20, 2009 | 02:05 PM
Listen to Chip - he knows what he is talking about and the products he sells are top quality.
Old May 20, 2009 | 03:28 PM
c5vetteguy's Avatar
c5vetteguy
Robert 2000, if you're forgoing the foglight screens because of access to the backside (where your V-ram attaches), this shouldn't be a problem. I, too, have purchased the Vararam with the intent of installing this at the same time as the screens. The screens that go into the foglight openings actually go in from the front (at least the RaceMesh do) and are pressure fit with double sided tape (included) or Velcro or tie wraps. You shouldn't need to remove the Vararam to put these screens in. I've also read that putting these screens in will help filter out the larger debris that will get sucked into the Vararam. Less cloggage should be a good thing...
Old May 20, 2009 | 05:41 PM
Robert 2000
Yea lol thanks I have the vararam in already I am just looking to hide its looks a lil and of course block some debris...plus I really like the mesh grill look
Old May 20, 2009 | 07:56 PM
dobewillie's Avatar
dobewillie
Chip knows his business
Old May 20, 2009 | 11:56 PM
Robert 2000
Ill take you guys word
To Inserts and Z06 screens
