I just bought a 2000 fob on ebay...I just noticed the gm# is not the same, but the canada # and the ID# are the same...Does anyone know if this Will still work with my car? This new fob has the passive switch as well..
I doubt it will work. If it has the passive switch then it's not a '00. You can try it, but I would ask for a refund because the '00 is unique from the others.
Is the passive switch pre 2000? they sold it as a 2000 fob...thx
From what I remember reading in the past it will work. Even if you have a pre 2000 you can use the newer fob you just will not have the passive feature on it.
