Does the 160 thermstat help or not?
Old May 20, 2009 | 09:00 PM
Nick1's Avatar
Nick1
Default Does the 160 thermstat help or not?
I have read a lot on this on the forum, and would like to know from those of you that actually have tried it; does the 160 degree thermo. actually help the LS1 run cooler? Thanks
Old May 20, 2009 | 09:31 PM
SaberD's Avatar
SaberD
it will on the highway, but not in city driving. You will have to reprogram the fans to keep it cooler in city driving. I wouldn't put in the 160 unless you do this, otherwise the engine will constantly be going through large temperature fluctuations, which is not good. If you aren't going to reprogram the fans, id go with the 180.
Old May 20, 2009 | 10:43 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
When you start adding big power mods and getting a tune done on the engine, most professional shops will install a 160 t-stat to help keep it cooler and enable them to tune better. As the other poster stated, you also need to reprogram the fans.
If your car is stock, or close to stock, it's a waste of time to mess with it. The factory settings and t-stat are fine.
Old May 20, 2009 | 11:04 PM
Chemdawg99's Avatar
Chemdawg99
St. Jude Donor '12 thru '21
Old May 20, 2009 | 11:11 PM
turbocrazy's Avatar
turbocrazy
I know some tuners won't even touch your car without a 160 tstat, provided that it is modded of course.
Old May 20, 2009 | 11:12 PM
damilleniumboy's Avatar
damilleniumboy
Something new that I learn today about the car. Mine went bad about 2-3 months ago, but I replaced it with the stock one.
Old May 20, 2009 | 11:21 PM
happa's Avatar
happa
I have a 160 and my fans are tuned for it. On the highway Ive seen between 179-180. Around town Ive seen the highest as 189. Sitting in line at the bank with 101 degree weather it was up to 191. Id say its worth it.
Old May 20, 2009 | 11:28 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
There use to be a funny sticky on the subject
Everyone has their opinion on the subject.
Since you asked, mine is no
Peace
Chip
__________________
..................Click for
Old May 21, 2009 | 12:14 AM
matt3310's Avatar
matt3310
Drifting<br><img src="/forums/images/ranks/2k-3k.gif" border="0">
2016 C7 of the Year Finalist
2015 C6 of the Year Finalist
Cruise-In X Veteran
St. Jude Donor '09 thru '19
It made a diffrence with my car!!!
Old May 21, 2009 | 08:55 AM
RSchleder's Avatar
RSchleder
I tend to agree with Chip!!!
Old May 21, 2009 | 09:46 AM
nickolbag's Avatar
nickolbag
To answer your question without personal opinion, assuming fans are reprogrammed then..............yes, definitely.
Old May 21, 2009 | 10:06 AM
stig-zzz's Avatar
stig-zzz
yes but need a reprogram of the fans
Old May 21, 2009 | 10:22 AM
ksvette74's Avatar
ksvette74
I am going to change mine, but I am on the highway most of the time. I also plan on changing fans settings as well. the 160 just opens earlier, and gets to full open earlier then the original. Air movement is what cools the fluid that cools the car engine. If you are flowing fluid, but not cooling the fluid, it is not going to matter. Fluid is cooled by the air moving when you are driving, or when you your fans are moving air. Hence the fan retune. To acheive cooler temps, you have to do both. One or the other will not make a huge diffrence all the time.
Old May 21, 2009 | 10:39 AM
Rossi396's Avatar
Rossi396
My fans are programmed and I run 186 to 188 or so in town and 174 to 180 on the highway. Not sure how you could say the 160 stat doesn't work. Previous temps were in the 225 range in city traffic with the stock unit....
Old May 21, 2009 | 11:02 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
With proper tuning changes made, yes it works. I went from stock temps hovering in the 210-220 range to a 160° thermostat and tuned it never goes above about 195 or so, even with the addition of turbo's and some rather spirited driving.
Old May 21, 2009 | 11:45 AM
8VETTE7's Avatar
8VETTE7
As stated by many above, without reprogramming the fan turn on temps, it is a wasted effort.
Old May 21, 2009 | 11:48 AM
nickolbag's Avatar
nickolbag
Huh? I said "yes, definitely" as in yes it will definitely work.
To Does the 160 thermstat help or not?
Old May 21, 2009 | 12:23 PM
GETOPLES's Avatar
GETOPLES
That's how I read it
Old May 21, 2009 | 03:44 PM
Rossi396's Avatar
Rossi396
Maybe I should have said, "Not sure how ANYONE could say the 160 stat doesn't work." I was agreeing with you...
Old May 21, 2009 | 04:08 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
No doubt re-programming the fans and changing to a 160 tstat will make the car run cooler, however, on a stock motor, what is the point? The car stock, was designed to run at the temp with the stock t-stat and fan settings. I doubt you are going to pick up HP or get better times at the track with changing the T-stat.. that is my opinion, and also what most tuners have told me.
