side trim
Old May 21, 2009 | 12:12 PM
OEM's Avatar
OEM
Default side trim
might be on here but im new searched on the regular net im wanting to remove that side trim is it as easy as fishing like or is there more involved, will it have really noticable clolor difference under it, or anything else? btw what are the wheels on the second one?
going from this...
to this...
Old May 21, 2009 | 12:46 PM
chris308's Avatar
chris308
fishing line would work, then use "goof off" stuff to get any residue left off the paint.
The wheels look like HRE's.
Old May 21, 2009 | 12:50 PM
tlc0706's Avatar
tlc0706
Removing body side molding (BSM) is documented here and will try to find you a thread. You will need fishing line (20 lb test), gloves and a sticky remover (3M). Some use a hair dryer or heat gun to soften the tape as you are sawing. Take the front fender piece off first to see if paint fade will leave a shadow in which case you will need to probably put it back on or paint the whole car.
The rims are HRE (www.hrewheels.com) and probably are in the $5000 a set range.
Good luck on the removal........
Tom
MaddChopper's Avatar
MaddChopper
St. Jude Donor '09
id like to do that too but im deff to scared that the paint under isnt gonna be right. i dont want to pay for a whole paint job if it goes wrong.
Old May 21, 2009 | 01:18 PM
tlc0706's Avatar
tlc0706
Only if the paint is faded would the paint job be necessary.....You could always put the BSM's back on.......
Old May 21, 2009 | 01:27 PM
Mike Mercury's Avatar
Mike Mercury
remove the BSM's (Buick Sedan Moldings) ???
Old May 21, 2009 | 01:31 PM
OEM's Avatar
OEM
dont really think it would be faded bad its an 02 w/32k miles but always been garaged or under a cover...
Old May 21, 2009 | 01:35 PM
MaddChopper
St. Jude Donor '09
mine is a 1998 its been garaged most of the years deff thro all the winters but im still scared about the paint being faded a lil bit. i wouldnt say im the most handy of people so this is why doing this scares me a lil bit. i deff hate that trim and have considered removing it myself before. Does anyone have details instruction on how to remove them????
Old May 21, 2009 | 02:17 PM
Bluefire's Avatar
Bluefire
The funnah is that the car is sooo low the only thing the BSM could protect you from is a go-kart (if it had doors).
To side trim
