ACA HID Ballast??
Old May 21, 2009 | 12:15 PM
cj68's Avatar
cj68
Default ACA HID Ballast??
Does the ACA kit use the XLD 144 or XLD 145 slim ballast? I have a newer kit with the slim ballast and need to order a replacement. I am hoping that someone knows the part number, so I don't have to pull the headlight apart to pull the ballast off for just a part number. The 144 and 145 appear to look the same, but I guess they are not compatible?
TIA,
cj
Old May 21, 2009 | 02:46 PM
horobosu's Avatar
horobosu
Cruising
I just checked mine, XLD 968
I got the kit a few months ago, so maybe new and improved?
Old May 21, 2009 | 04:05 PM
cj68's Avatar
cj68
Dam... and I just ordered an XLD 145. What is the difference between the 144, 145, and 968?
cj
Old May 21, 2009 | 06:12 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
cj
I would venture to guess differences in internal circuitry. The XLD 968 appears to be an older model specific for D1S bulbs. The XLD 145 is designed for aftermarket use and is not OEM equipment on any currently built vehicle. Think of it as a middle of the road from chinese HID kits and Hella, Bosch and other OEM equipment.
Old May 21, 2009 | 08:22 PM
blue63cpe's Avatar
blue63cpe
My ACA ballasts are Philips the #'s are 4557 9634 and I have the bar code if you want. I put these in about 2yrs ago.
To ACA HID Ballast??
