[Z06] lowering...
Old May 27, 2009 | 07:58 AM
crAzy's Avatar
crAzy
Originally Posted by Toque
SWEET ! Man you can't beat a lowered Z06 with ANY CCW wheel,,
Thanks!
Old May 27, 2009 | 09:04 AM
iLLuZionZ's Avatar
iLLuZionZ
^ do you rub a lot and do you notice any negative adverse affect on handling from dropping it that low?
also what is the proper procedure to remove the fronts completely? I tightened them until they wouldnt go anymore and then back 1/8 turn and it looks nowhere near as alow as yours.
Old May 27, 2009 | 09:44 AM
crAzy's Avatar
crAzy
I dont rub at all... Now i have notice (not sure if its from lowering) but when i go in reverse and back up and turn. I hear like a creeking noise. I think its the ball joint of whatever and has nothing to do from lowering. The handling is better IMO. Less body roll. Now the rear i actually had lower but it got really bouncy over humps or dips on the road. So i raised it back up and added all but one piece of rubber gromet. I had a total of 3 removed in the back. There is a total of 4 i believe. What i did was cut them with a saw. You will see how they can be cut to make them shorter once you get them off...
Now the front. What i did was jack it up and remove the wheel. I had to unbolt the steering knuckle and drop down the a arm and pry it open with a bar or something. Then i was able to twist out the bolt. I stripped one so i had to use pliars and wow did it take a long time lol... The other side went perfectly easy. I suggest spraying it with some wd-40 or something with lube...I also went to get an alignment after about 100 or so miles. Cause it takes some time to drop.
Old May 27, 2009 | 10:16 AM
Sandman93's Avatar
Sandman93
LOOKS incredible
Old May 27, 2009 | 10:22 AM
crAzy's Avatar
crAzy
Originally Posted by Sandman93
LOOKS incredible
Thanks as well if you were referring to mine or his!?
Old May 27, 2009 | 10:24 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Originally Posted by 1SHADYZ
I was wondering if my 14" Rear Baer Eradispeed rotors would fit my stock Z06 rear wheels. I guess that answers my question huh ?
Anything special you have to do to make it work ?
Toque
Old May 27, 2009 | 11:52 PM
1SHADYZ's Avatar
1SHADYZ
Toque
Nothing that I know. They came with the car when I bought it.
