Airconditioner problems
Old May 23, 2009 | 03:51 PM
MATT-X's Avatar
MATT-X
Default Airconditioner problems
Anyone else have them? Mine wont stay operational for more than a few weeks! Its gettin hott and i can only go so fast with the windows down...
I push the a/c button and it blinks a few times then goes off?
Old May 23, 2009 | 05:44 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
When the ac button blinks, it usually means its low on freon. My guess is you have a leak somewhere in the system. Also, check the codes on the DIC and post them. More than likely though, you've got a leak somewhere.
Old May 23, 2009 | 06:11 PM
Old Rotor Head's Avatar
Old Rotor Head
Had the same thing a few years ago. The freon in-put valvue stem had a slow leak. Changed it, refilled and it's been 3 years with no issues.
Old May 23, 2009 | 08:50 PM
MATT-X's Avatar
MATT-X
Thanks guys ill try that. Thought it was gonna be a hot summer!
Old May 24, 2009 | 11:07 AM
jimcork1's Avatar
jimcork1
I highly you get a leak detector put the car in a closed garage and check for leaks. If you are only getting 3 weeks you have a leak.
My 99 has 78,000 miles bought it new and this week I checked the freon and added 4 oz to top it off. After 10 yrs this isn't bad.
But 3 weeks sends you hunting for a leak. If you don't have a leak detector and want to check the joints make up some dishwash soap and water and do a bubble check on the joints where the o-rings are.
To Airconditioner problems
