[Z06] Windsheild Replacement
Old May 23, 2009 | 09:12 PM
Brian_B's Avatar
Brian_B
Default Windsheild Replacement
I'm thinking of buying a 2002 Z06. The one I want has a cracked windshield from a rock. I heard that once replaced, the seal is crappy and its just not the same. Any comments or experiences would be helpful. Thanks.
Old May 23, 2009 | 09:56 PM
BitViper's Avatar
BitViper
The quality of teh seal has everything to do with the installer..
Do a search on my name and DW1430..youll save a bunch of bucks
Old May 23, 2009 | 10:55 PM
Brian_B's Avatar
Brian_B
Thanks. Will do.
Old May 23, 2009 | 11:23 PM
Bill Dearborn's Avatar
Bill Dearborn
I am on my second replacement windshield and second installer. The first one leaked and they couldn't get it to stop. The second one leaks as well. Trying to get it to stop leaking.
Bill
Old May 24, 2009 | 12:32 AM
Brian_B's Avatar
Brian_B
Thanks. I think I'll buy it and find a good installer and be absolutely clear that I want a 100% professional job.
Old May 24, 2009 | 04:04 AM
LT1driver's Avatar
LT1driver
problem is all installers think they are professionals and do professional work word of mouth from friends etc. best way to get it done right. good luck
Old May 24, 2009 | 10:53 AM
BitViper's Avatar
BitViper
Roger that..My installer was froma nationally recognized company..but it still leaked...it took them two visits to get it right...
Make sure the company has a "We'll make it right clause" and do TEST their installation and look for leaks the day after the install. Leaks are generally around the 'A" column..soak the car realy good and then look for wet carpet
Old May 24, 2009 | 12:07 PM
NatB's Avatar
NatB
I had my Z06 windshield replaced by an installer recommended by a local Corvette place. Took the installer 3 passes total to get the seal around the right door. The windshield seal itself was no issue- it's all the door and trim that is a PITA on the C5 ( I watched- it is a lot of work). He got it right finally so all is well.
A good installer is key - even if he has to do the job twice, at least if he is experienced with C5's he'll know what he did wrong.
Incidentally - I chose the non-HUD replacement for my driver- the HUD works fine and with all the debree on the roads around Houston it made more practical sense for me.
To Windsheild Replacement
