GHL Install Question - is this correct?
Old May 24, 2009 | 03:07 PM
Fire 22's Avatar
Fire 22
Default GHL Install Question - is this correct?
I am installing my new GHL exhaust and I put the tips on and noticed the left set almost comes to the center and the right side set is too far right. I pulled the tips off and noticed the left side is 2 1/4" longer than the right side tips. Is this right and if so what am I doing wrong - the muffler position is set by the hangers, they cant move.
Old May 24, 2009 | 03:25 PM
Tim04C5's Avatar
Tim04C5
I think you unfortunately have your mufflers on the opposite (wrong) sides.
Look at #58 - http://forums.corvetteforum.com/c5-g...-shipping.html
Old May 24, 2009 | 03:31 PM
Ed_78Vette's Avatar
Ed_78Vette
A call to the vendor is in order!
Old May 24, 2009 | 07:14 PM
34RedRage's Avatar
34RedRage
i just checked my bullets out and mine are the same size on both sides...get in touch with your vender....
Old May 24, 2009 | 07:40 PM
dobewillie's Avatar
dobewillie
call vendor good luck
Old May 24, 2009 | 07:50 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
When I had my system installed the right side tips just wouldn"t line up. The were equal in length but just the way they were welded, the angles were off. I contacted the vendor and GHL made good with a new set of tips. Haven't gotten time to replace the originals but I felt their service was top notch.
Old May 24, 2009 | 08:03 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
They are 100 % correct
Those are correct, the pass side is longer than the D/S
Start by loosening up your whole system all the way back to the H/X pipe.
Also lube up the inside and out side of the slip overs joints to insure that
the system is slid all the way together at the joints
The system is not Asymmetric.
You will also notice that the hangers are different lengths from the ends of the can.
I've hung at least 8 in the last two weeks.
Regards
Chip
__________________
..................Click for
To GHL Install Question - is this correct?
