[Z06] Steering wheel sensor
Old May 24, 2009 | 10:03 PM
nighteu4ia's Avatar
nighteu4ia
Default Steering wheel sensor
Does anyone know If the 2002 z06 has a steering wheel sensor that needs to be calibrated after a wheel allignment is done?
Old May 24, 2009 | 11:37 PM
James92's Avatar
James92
yes there is a sensor. if your steering wheel is too far off center while driving straight it will trigger a code.
Old May 25, 2009 | 09:50 PM
99FewteRC5's Avatar
99FewteRC5
No calibration is necessary...after alignment..
Old May 26, 2009 | 12:55 AM
Bill Dearborn's Avatar
Bill Dearborn
The only time the SWPS has to be centered is when it is being installed. Centering the SWPS is not part of the wheel alignment procedure.
Bill
Old May 26, 2009 | 04:10 AM
nighteu4ia's Avatar
nighteu4ia
thanks for the info.
Old May 26, 2009 | 04:11 AM
nighteu4ia's Avatar
nighteu4ia
thanks for the good info
Old May 26, 2009 | 09:48 AM
stas's Avatar
stas
Default Re:
Does anyone know how far does the steering wheel have to be off center for the code to be trigerred? My steering wheel is noticeably off center (planning to ge an alignment done), but the code does not get triggered right away for some reason, but after some driving. Could bad alignment be the culprit here?
Thanks.
Old May 26, 2009 | 10:36 PM
99FewteRC5's Avatar
99FewteRC5
Your alignment would have to be off a good amount to set a steering sensor code. What code is it setting? c1287 or 1288 is more than likely a steering sensor going bad.
Old May 27, 2009 | 01:04 AM
nighteu4ia's Avatar
nighteu4ia
No codes being tripped. Just pulls to the left a little after an allignment and after a re-check of the allignment. Might be a tire issue.
Old May 27, 2009 | 01:06 AM
nighteu4ia's Avatar
nighteu4ia
Sorry thought that was for me.
Old May 27, 2009 | 01:37 AM
99FewteRC5's Avatar
99FewteRC5
cross the frt tires left to right and see if it pulls right. if it does, its the tire
Old May 27, 2009 | 09:58 AM
stas's Avatar
stas
Default Re:
I'm getting the c1287 code. Yesterday I got it right when I started the car.. turned the wheel a little bit to straighten the wheels and pull out of the garage and the code was set. So it's more likely the sensor?
Old May 27, 2009 | 10:48 PM
99FewteRC5's Avatar
99FewteRC5
more than likely....i see that quite a bit.
To Steering wheel sensor
