Best way to replace rotors?
Old May 25, 2009 | 07:31 PM
AuburnShrink's Avatar
AuburnShrink
Default Best way to replace rotors?
Hey guys. 1998 vert member here.
I have searched the forums and found lots of info on replacing my front rotors and brake pads. It was a very easy process to remove the calipers and the rotors.
I have one problem.
My new pads are too thick to allow me to mount them back around the new rotors. I read where I can use a c-clamp to compress the piston, but I do not want to compress it in the wrong place and distort it.
How can I compress the caliper pistons back so I can put the darn thing back together?
Thanks so much and very sorry if this is a dumb question.
Old May 25, 2009 | 07:45 PM
JerzeyJoe's Avatar
JerzeyJoe
What I do is I place one of the old shoes between the c-clamp and the piston. I then push the piston in. Never had a problem.
Old May 25, 2009 | 07:49 PM
VetteDawg's Avatar
VetteDawg
Make sure you take the master cylinder cap off before compressing the caliper. You may have to remove some fluid. I bought a turkey baster to remove fluid.
Use a c-clamp. I use a piece of wood on top of the cylinder...but whatever works. Compress it all the way so you can get the new pads on. Remember to use some of that anti squeak stuff on the back of the pads.
Old May 25, 2009 | 08:00 PM
Navyvette04's Avatar
Navyvette04
Using an old brake pad with a c-clamp is the way to go. Just remember to check the fluid in the master cylinder prior to compressing the pistons. If the fluid is up to the top, remove some fluid. I have a brake bleeding tool, but a turkey baster works also.
Old May 25, 2009 | 08:01 PM
Joy of 6's Avatar
Joy of 6
I've got a cheap harbor freight tool that works but use the old pad at the base of the pistons and as above remove the master cylinder cap and maybe some fluid. This will be a good time to bleed your brakes if it has not been done for a while
Old May 25, 2009 | 08:13 PM
Nepthalim's Avatar
Nepthalim
Old May 25, 2009 | 08:21 PM
Jet-Jock's Avatar
Jet-Jock
Remove about 3/4 fluid before compressing the cylinders. In theory you should not need to open the bleed line. You probably will need to replace the caliper bracket mounting bolts. They are usually a one torque only. I've done them on the C4 which is probably much easier, but those bolts hold a lot of torque. I'd have to look the values up on a C5 setup. Best to review the FSM procedure for other items that must be replaced and not used, and for torque values.
Old May 25, 2009 | 09:09 PM
Bill Dearborn's Avatar
Bill Dearborn
Theoretically, if nobody has added fluid as the pads have worn (they shouldn't but some people do) when you push the pistons all the way back the fluid should come back to the full line. Watch as the M/C reservoir as you push the pistons back one caliper at a time. If the level gets close to the top then suck some fluid out. If you plan on bleeding the brakes along with replacing pads and rotors suck as much out as possible before compressing the pistons.
Bill
Old May 25, 2009 | 11:24 PM
AuburnShrink
Thanks for all the helpful feedback!
I love this place (Corvette Forum) and cannot imagine owning a Corvette without this resource.
I would have spent at least a few thousand dollars on mechanics over the past 2 years of ownership without the help.
I will give the above tips a try and see how it goes.
Old May 26, 2009 | 01:19 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Old May 27, 2009 | 08:55 AM
RSchleder's Avatar
RSchleder
I agree with the suggestions shown above. I just redid my rotors and pads a couple of weeks ago. I took the master cylinder cap off when I compressed each of the individual calipers. I didn't need to remove any fluid, I just placed a paper towel folded over several times on the top of the Master cylinder to "soak-up" any small amount of overflow. This worked GREAT. I also put the master cylinder cap back on after each wheel was done and pumped the brake several times to get a firm peddle before going on to the next one. When completed everything worked perfectly and I didn't need to do any "bleeding".
Old May 27, 2009 | 09:08 AM
bucwheat's Avatar
bucwheat
Easy job.
Old May 27, 2009 | 10:15 AM
slothy's Avatar
slothy
make sure the parking brake is off when ya goto do the rears
Old May 27, 2009 | 10:32 AM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Old May 27, 2009 | 10:56 AM
That process works very well.
To Best way to replace rotors?
