noise
Old May 29, 2009 | 08:46 PM
buckg2's Avatar
buckg2
Default noise
quick run down- 04, vert, auto, 19000 miles. May just not of noticed before, but just installed new cat back and now under hard acceleration when the car shifts to 2nd gear there is a some what tinny sounding loud snap from the rearend. My guess maybe the tires are breaking loose a little and this is the limited slip kicking in. First the noise seemed to come from the pass side only but tonight i herd from the pass side first and a split second later from the drivers side. One of my other thoughts is the fiber-glass leaf. any ideas fellas???
Old May 29, 2009 | 08:54 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Have you got back under there to take a "CLOSE" look to see if anything is hitting or rubbing when it shifts?
Get a flash light a browse around and look closely for any signs of wear or hitting!
Also make sure that when you re-installed your new exhaust that you put the muffler tabs in the top part of the Rubber Hangers and not the lower ones where it can slide from side to side
Let us know!
Thanks,MAtt
Old May 30, 2009 | 10:23 AM
buckg2's Avatar
buckg2
ttt
To noise
