Intake cover question
Old May 30, 2009 | 05:18 PM
Munch's Avatar
Munch
St. Jude Donor '10
Default Intake cover question
I noticed that some of the intake covers out there are 2 pieces while others are only once piece. Does anyone know the reason why some are 2 pieces and do they look the same as the 1 piece when they are installed?
Thanks.
Old May 30, 2009 | 05:53 PM
hotwheels57's Avatar
hotwheels57
For ease of installation due to the fuel rail cross over on top of the intake...
Old May 30, 2009 | 05:55 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Correct.
The single is cleaner, but requires the fuel rail to be removed.
The two piece is for non-mechanics.
Old May 30, 2009 | 10:09 PM
bucwheat's Avatar
bucwheat
Some of these covers hold in heat, which is not a good thing at the track.
Old May 30, 2009 | 11:34 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Originally Posted by ~JOSHUA
Correct.
How difficult is it to remove the fuel rail? I noticed the one-piece vs. two-piece design as well and was also curious.
Also, regarding the comment about holding in heat during track use, etc., what effect, if any, would this have on a painted or hydrocarbon piece?
Old May 30, 2009 | 11:49 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The fuel rail lift is easy. There are (4) 10mm bolts that hold the rail to the intake manifold. Once those are loosened, lift the rail evenly straigt upward. It takes a little force to because all eight fuel injector o-rings will be reluctant to move. Make sure the injector bores are clean before starting the whole thing back down. Make sure they are aligned and press downward gently at different points. Tightening the bolts down again fully seats everything.
The main drawback to the full cover is that you have to remove it if you ever need the throttle body off, which requires the rail lift again.
The heat soak issue is such a joke on ls1tech.com (where true gearheads hang out) An aluminum intake will lose less than 10hp on a 500hp engine. My twin turbo ls1 did just fine. Don't worry about a skimpy little cover over the intake.
Last edited by ~Josh; May 30, 2009 at 11:55 PM. Reason: I-phones make it easy to have lots of typos
Old May 31, 2009 | 12:03 AM
I had a two piece on mine - made for a very easy installation since you didn't have to mess with the fuel rails. And yes, you can see the line between the two pieces, but it does not look bad IMO.
To Intake cover question
