Need Help With C5
Old May 31, 2009 | 02:55 PM
ewtroutjr's Avatar
ewtroutjr
5th Gear
Default Need Help With C5
I have a 99 Vette that I have some questions about.
- I have a automatic that the shift indicator is broke. I took it apart today and the orange piece is broken. Is there any way to fix this or is this a part that just has to be replaced?
- My driver and passenger seats slide back and forth, like they are loose on the tracks. Do I need to purchase new tracks or is there a fix?
- I am in Pensacola, FL does anyone know a place that I can get the car tuned? Whoever had the car before has the shift points set so it won't shift unless I bring the RPMs up pretty high.
- Has anyone cut the black covers out around the fog lights and out of the louvers behind the front tires? I figured that if I got rid of those covers it will let more cool air in and let the hot air exit. Will this work?
- Last question I have for now is the side bumpers. Has anyone removed them? If I parked next to someone I understand that they will protect my doors from dings, but I don't park anywhere near people. I have seen pictures of C5's without these and I like that look better.
Any help I can get I appreciate it.
Earl
Old May 31, 2009 | 03:24 PM
MagRedConv's Avatar
MagRedConv
- I have a automatic that the shift indicator is broke. I took it apart today and the orange piece is broken. Is there any way to fix this or is this a part that just has to be replaced? Sounds like the easiest thing to do is simply replace it.
- My driver and passenger seats slide back and forth, like they are loose on the tracks. Do I need to purchase new tracks or is there a fix? Check out the Ultimate DIY sticky in the Tech Section
- I am in Pensacola, FL does anyone know a place that I can get the car tuned? Whoever had the car before has the shift points set so it won't shift unless I bring the RPMs up pretty high. Someone may chime in on this but you can always check out the Regional Section and/or ask folks in local vette clubs.
- Has anyone cut the black covers out around the fog lights and out of the louvers behind the front tires? I figured that if I got rid of those covers it will let more cool air in and let the hot air exit. Will this work? This has been done though I don't recall any hard temp data.
- Last question I have for now is the side bumpers. Has anyone removed them? If I parked next to someone I understand that they will protect my doors from dings, but I don't park anywhere near people. I have seen pictures of C5's without these and I like that look better. Many have removed them. If you click Search This Forum in the upper right and type BSM removal you'll find more threads than you can imagine.
Earl
See above in red
Old Jun 1, 2009 | 07:46 AM
ewtroutjr's Avatar
ewtroutjr
5th Gear
Old Jun 1, 2009 | 10:31 AM
I've got a few Word files that discusses the rocking seat fix. If you would like a copy, PM me your e-mail address.
As for the body side moldings, you can remove them by using a hair dryer to heat the two sided tape that holds them on and then using some fishing line to saw through the tape. It helps if you have a helper to pull up on the molding as you go along.
Old Jun 1, 2009 | 08:16 PM
ewtroutjr's Avatar
ewtroutjr
5th Gear
My email address is ewtroutjr@yahoo.com. I would appreciate any instructions you have that will help me fix the problems.
Old Jun 1, 2009 | 08:19 PM
ewtroutjr's Avatar
ewtroutjr
5th Gear
When I remove the side moldings are there any holes that have to be patched? Also has anyone ran into the problem that the paint under the molding does not match the rest of the car (faded paint or just primer under the moldings)?
Old Jun 1, 2009 | 08:35 PM
spdracr39's Avatar
spdracr39
Anytime you do a search always do "advanced search" or you will get a million unrelated threads.
To Need Help With C5
