Need help with tire sizes
Old Jun 1, 2009 | 01:12 PM
beaversta's Avatar
beaversta
5th Gear
Default Need help with tire sizes
I have a 19/20" set up no my 01 z06. The front tires are 255/35/19's and I need some new back tires. I was wanting to go with 305/25/20's will this work or will I have tracktion control issues? Thanks
Old Jun 1, 2009 | 01:42 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The front and rear tire sizes are almost identical in overall diameter. Since the traction control system is expecting to see the rear tires rotating slower than the fronts, it is not only possible, but likely that you will have an issue.
Depending on the width of the wheels, you might consider adjusting the sizes.
Here is the tire calculator that I used -
http://www.discounttire.com/dtcs/infoTireMath.dos
Check tire size availability, and plug your choices into the calculator.
Old Jun 1, 2009 | 03:48 PM
beaversta's Avatar
beaversta
5th Gear
How large of a differance does it have to see? Thanks
Old Jun 1, 2009 | 06:12 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Approx .75" to 1"
To Need help with tire sizes
