headlight trouble c5
Old Jun 2, 2009 | 09:50 AM
ramblinrelic's Avatar
ramblinrelic
2nd Gear
Default headlight trouble c5
I have a 2001 c5 that the left front headlight motor was not working when I bought the car, it would run on after the lights were turned on or off and the gear was stripped inside the left headlight motor. So I replaced the gear for about 30 dollars ,pretty simple fix and it worked good for about 20 times and it stripped the gear again . So I bought a gm headlight motor this time it sells for 330.00 and replace the thing now the left headlight cycles up and down 4 times when you turn the lights on or off, but it does end up in the open position when you turn it on and closes when you close it but it also cycles 4 times then closes any help would be appreciated . Thanks .Frank P.S. THE RIGHT HEADLIGHT WORKS PERFECTLY !
Old Jun 2, 2009 | 10:33 AM
jsls0130's Avatar
jsls0130
Welcome to the forum, you should post your question in the C5 tech section. You will get a better response.
Old Jun 2, 2009 | 10:34 AM
RicK T's Avatar
RicK T
Welcome to the Forum!!!!!!! Enjoy.
You need to post your question over in C5 General where the C5 owner members will help you:
http://forums.corvetteforum.com/c5-general-103/
Old Jun 2, 2009 | 02:26 PM
csexton's Avatar
csexton
Welcome
Chuck
Old Jun 2, 2009 | 02:36 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Jun 2, 2009 | 03:28 PM
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
Sounds like you need these.
http://my.execpc.com/~rodney1/vettegears/index.htm
Old Jun 2, 2009 | 04:55 PM
02MillenniumVette's Avatar
02MillenniumVette
Originally Posted by Johnny_B_Good
You need the brass gears, otherwise if you just replace it with another nylon gear, it will continue to strip.
Old Jun 2, 2009 | 05:48 PM
RSuperfreak3's Avatar
RSuperfreak3
Waste of time to replace a stripped gear with more nylon crap! Get the brass gear and be done with it!
To headlight trouble c5
