Key Fob Problem
Old Jun 2, 2009 | 12:37 PM
stanfan's Avatar
stanfan
Default Key Fob Problem
One of the key fobs for my '99 vert has gone south on me. I replaced the battery. I went through the fob training process per the owners manual. The fob then worked fine once, but then became nonfunctional again...even after I redid the fob training process. Can the fob be repaired? If so, where? If not, where is the best place to buy a replacement? Thanks for any suggestions.
Old Jun 2, 2009 | 12:41 PM
poolboy's Avatar
poolboy
try this - http://forums.corvetteforum.com/c5-t...em-solved.html
or order a new one from Gene at gmpartshouse.com
Old Jun 2, 2009 | 01:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Agreed. They seem to die after 8 or 9 years. Sometimes they find a broken IC connection inside and other times, nothing is visible. About all you can do is replace them. Gene Culley has the best price on them.
Old Jun 2, 2009 | 04:59 PM
stanfan's Avatar
stanfan
Default Thanks
Thank you for the suggestions.
Old Jun 4, 2009 | 01:10 AM
sbadd99's Avatar
sbadd99
yeah just had mine die a couple of weeks ago, replacement $58
To Key Fob Problem
