Just got my bilsteins
Old Jun 3, 2009 | 04:31 PM
Vettelover1990's Avatar
Vettelover1990
Default Just got my bilsteins
ok so i just just my BS sport shocks. does anyone know a good cheap place to install in south florida?
Old Jun 3, 2009 | 04:37 PM
waktasz's Avatar
waktasz
Your garage.
I'm serious. I am by no means a good mechanic. I would never on my life attempt to do anything to my motor, but installing Corvette shocks are an easy job.
Old Jun 3, 2009 | 05:15 PM
Vettelover1990
i would!! i want to now!! but i dont have a lift....
Old Jun 3, 2009 | 05:27 PM
ecoman's Avatar
ecoman
Did mine with a floor jack and jack stands.Not hard at all.
Old Jun 3, 2009 | 05:29 PM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
You can use mine if your up for a drive up!!!
Old Jun 3, 2009 | 05:33 PM
Vettelover1990
ok anybody have a link to DIY: changing c5 shocks?
Old Jun 3, 2009 | 05:42 PM
jrprich's Avatar
jrprich
Here you go.........pretty easy when I did it.
http://www.inlandempirecorvettes.com.../c5shocks.html
Old Jun 3, 2009 | 05:45 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
The same write up I used. If you drink go pick up a 12 pack before you start. You will need a little patience, but it's not that bad.
Old Jun 3, 2009 | 05:47 PM
Lenrock's Avatar
Lenrock
Good choice on the Bilsteins. I just did that install last week. It wasnt that hard. It took me a few hours but I really took my time too. Nice shock and its not so hard of a ride that youll be picking up your teeth off the floor either.
Old Jun 3, 2009 | 05:52 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You don't need a lift here is a how to:
http://www.c5forum.com/diy/shocks.php
This should help for you to do it yourself
Thanks,Matt
Old Jun 3, 2009 | 08:27 PM
71corv's Avatar
71corv
St. Jude Donor '08
Works the easiest if there are 2 pair of hands/arms doing the work. Did mine on jack stands with no problems.
Gene
Old Jun 4, 2009 | 09:07 AM
waktasz's Avatar
waktasz
Did mine with one jack and one jack stand. Did the fronts by myself, then made my codriver do the rears because I had a dinner date
Old Jun 4, 2009 | 09:13 AM
bucwheat's Avatar
bucwheat
Easy job.
Old Jun 4, 2009 | 10:22 AM
Jims79's Avatar
Jims79
to agree this is one of the easy do it yourself jobs, you can do at home. save the money you would have given to a shop for beer & gas....
Old Jun 4, 2009 | 01:03 PM
Vettelover1990
stupid question???
do the bilstein sports already come compressed or do i have to do the zip tie meathod?
Old Jun 4, 2009 | 01:13 PM
waktasz's Avatar
waktasz
If you take the upper control arm off you don't need to compress the shock to fit it in there. I just took the two bolts holding it in off, but remember the position of the washers behind it or your alignment will go all crazy.
Old Jun 4, 2009 | 04:41 PM
B-Vette's Avatar
B-Vette
Great write ups and info.
Old Jun 5, 2009 | 01:27 AM
lucky99's Avatar
lucky99
since you just got shocks, new C6 sway bars would make a big difference. Gene Culley has a great deal 108.00 front and rear. Z06 or z51. Z06 are a little higher
Old Jun 5, 2009 | 01:31 AM
DuronClocker's Avatar
DuronClocker
This is the best option if you're doing it by yourself. If you've got an extra pair of hands, two of you can muscle it in without needing to do this.
To Just got my bilsteins
