Which one did you go with/is best. I see four. They are all different heights. Which ones will fit under a 2004 C5? I'd like a new jack for my C4 that can also get under dad's C5.
Here's another angle... right where it says "Front Mounting Brackets" is where you want to jack from. You can see the 2 "ribs" of the crossmember here... just want to make sure the jack pad touches them both. All pics have been taken from www.ls1howto.com which is a great resource.
COBRA...excellent pics and help...much appreciated!!
ITEM 91039-9VGA $99.99 3" to 14 3/4" 3000 lb
This one is what I have and it works great!!! Small, lightweight and gets under my lowered stock bolts with no problems.
Keep you eye on the sale flyers as they go on sale for $79.99 quite frequently.
I got my floor jacks from wal-mart. $30 for the smaller one I bring to the track and $95 for the bigger one I use at home. they are not lightweight aluminum ones but they get the job done the same way a $300 "aluminum racing jack" will. didn't cheap out on jackstands. got 6 ton craftsman. figured if the jack fails no big deal, if the jackstand fails im dead.
You just decided for me on which one to buy from HF...thanks alot!!
Just to clarify... you jack from the metal crossmember that those words are covering up... NOT WHAT THEY POINT TO. They're pointing to the spring brackets that hold the front monoleafe to the cradle.
Never jack on the spring and never get caustic cleaners around it.
I just got two sets of 3ton Hein-Werner jackstands from toolrage.com. They had great customer service, free shipping on orders over $150, and the jackstands seem pretty well built and are made in the USA. It took me quite awhile to find ones that weren't Chinese, but it was worth it.
I use a Sears aluminum low profile jack and 2 ton jack stands on my cars. Works well and when I had my C5, the jack was low enough to easily fit under the car with jacking pucks installed.
