From: HOME OF THE FREE. BECAUSE OF OUR BRAVE. Babylon NY
St. Jude Donor '06 thru '20
Tail light relay & harness
There is a relay on one of my tail lights it's connected to a harness that plugs into a socket (hope I explained this correctly). Any way the plug taht go's into the socket is corroded and I need a part number or even a name for this part (harness).
I think you're talking about the ground splice pack. Just take it apart and use some electrical cleaner to clean up the contacts.
i had this issue as well, i went right down to the local auto zone or schucks and i found the replacement harness/plug right in their "light/bulb" section's reference book. If i remember correctly it was like $6
i had corroded wires to the point that they broke, and contact were corroded as well.. i just bought a new plug which comes w 4" of new wires also, and spliced the old and new wires together. good as new
