Simple question:
Old Jun 5, 2009 | 04:27 AM
tez_14_2000's Avatar
tez_14_2000
Default Simple question:
Hey, i just wanted to check, how do the red engine covers come off the top of a C5 motor?
Im assuming they just pull upward? but im terrified of breaking them.. not so easy to get them in Ireland! lol
Cheers,
Terry.
Old Jun 5, 2009 | 04:43 AM
tsts's Avatar
tsts
Cheers,
Terry.
Simple answer: Yes, pull them (4 mounting points)
Old Jun 5, 2009 | 07:15 AM
love my car's Avatar
love my car
Yes just firmly pull off,First time i did it i found a mouse nest!!!!!!!!!!! So i do it every few weeks exp. in the cold months.
Old Jun 5, 2009 | 07:56 AM
02MillenniumVette's Avatar
02MillenniumVette
Old Jun 5, 2009 | 09:14 AM
jrose7004's Avatar
jrose7004
I pull from the bottom firmly.
Old Jun 5, 2009 | 10:20 AM
Pull them up and then you can flex the area where the fuel line goes through to get the driver's side cover off.
Old Jun 5, 2009 | 10:22 AM
bucwheat's Avatar
bucwheat
If you paint them ,upon replacing the,tape the fuel lines to keep from chipping your new paint.
Old Jun 5, 2009 | 10:29 AM
Dominic Toretto's Avatar
Dominic Toretto
I was scared to pull mine off too but, as stated yes the just unclip
-Alex
Old Jun 5, 2009 | 10:33 AM
poolboy's Avatar
poolboy
Hi Terry, start along the outter edges of each side and lift upwards. Once that side is loose them you can easily lift off the inner sides. For the side with the oil fill cap - you'll have to remove the cap first, and on the side with the fuel line(s), you'll have to work the fuel line out of the cutout in the cover. Th covers are fairly flexable so you shouldn't break them.
Old Jun 5, 2009 | 12:36 PM
tez_14_2000
thanks for the many friendly replies folks.
Ill have a poke at it tomorrow probably.
Thanks again,
Terry.
Old Jun 5, 2009 | 01:22 PM
Redhawg's Avatar
Redhawg
Good info here you can do it. Good luck
To Simple question:
