[Z06] c5 z06 general questions
I was sitting in traffic yesterday 94 degrees and and coolant temp was showing 227deg. normally it is 194-201deg. Is that to hot for these cars?
I am to going to take the fan shroud off and clean out any dirt between the condenser and rad. Also I am going to put som water wetter in it.
Running a Vararam ram air, it is using a green foam air filter, can i replace this filter with a better quality filter like k/n or non foam filter, where can i buy and what would be part number I am assuming this would not be stock air filter size
Also I have been looking for those headlights for c5 that are 4 round lights that replace the stock headlight but are still pop up style if someone could post up link to them or where I can buy them.
I ran my car in the 1/4 and it ran 12.2 @118.9 with stock tires.
(my buddy with his evo that runs 12.79 Is tweaking more so i was just wanting to up the game on him
)If i was to put some drag radials on it do I need to change anything in the rearend to keep it from exploding?
I saw a cts-v in front of me (at the strip) with drag radials drive through the water box and smash the gas and peel out an then traction hop then bang rearend was dead. He killed the rearend due to his method of heat the tires then traction hop and not letting off. But i guess my question is what breaks in the rearend. and can it take drag radials if burnouts are done correctly?
thanks for your time
Jay
Stuff Rocks.
