Callaway Wheels
Old Jun 6, 2009 | 10:29 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Default Callaway Wheels
Do the new 9 spoke wheels from Callaway fit up to the C5??
They're currently fitted on their C6 offerings. Wanted to know if the offset is the same or if spacers are needed?
Old Jun 10, 2009 | 11:59 AM
mcv's Avatar
mcv
You can always call us at Callaway direct with questions like this (860 434 9002, Mon-Fri, 8:00-5:00 eastern US time).
The wheels are designed for C6 applications, the offsets are not correct for C5's. On a non-Z06 C5, the fronts stick out by 9mm and the rears might contact the inner fenders.
Here's the story from our Engineering Dept:
OE C5 Front 17" x 8.5" ET 56
OE C5 Rear 18" x 9.5" ET 65
OE C5 Z06 Front 17" x 9.5" ET 54
OE C5 Z06 Rear 18" x 10.5" ET 58
OE C6 Front 18" x 8.5" ET 56
OE C6 Rear 19" x 10" ET 79
OE C6 Z06 Front 18" x 9.5" ET 40
OE C6 Z06 Rear 19" x 12" ET 59
Callaway C6 Front 18" x 8.5" ET 47
Callaway C6 Rear 19" x 10" ET 70
Which means the inner and outer rims will end up in these positions on a C5:
Our wheel on a regular C5:
Front - 9 mm more inner clearance, outer position will extend by 9 mm
Rear - 11 mm less inner clearance, outer position will extend by 1 mm
Our wheel on a regular C5 Z06:
Front - 20 mm more inner clearance, outer position will retract by 6 mm
Rear - 6 mm less inner clearance, outer position will retract by 18 mm
Old Jun 10, 2009 | 04:43 PM
jdmvette's Avatar
jdmvette
Night Owl for life
good post, mcv.
what do these wheels look like?
Old Jun 10, 2009 | 04:50 PM
bucwheat's Avatar
bucwheat
Thanks for clearing that up.
Old Jun 10, 2009 | 06:04 PM
mcv's Avatar
mcv
Originally Posted by jdmvette
good post, mcv.
This link has part numbers and prices of the various finishes:
http://www.callawaycars.com/callaway...eWheelPage.htm
More pictures tomorrow.
Old Jun 10, 2009 | 08:39 PM
stingraymyway
Dang.
When the pics of these wheels get posted, you'll feel my pain.
Old Jun 10, 2009 | 09:35 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Dang.
those wheels do look good.
i honestly don't think that those extra +9mm up front will stick out and be noticible.
and in the rear, if it sticks too far inward, you can always space it out.
either way, you can get these wheels to work...provided you can afford them as i'd imagine they're expensive.
Old Jun 10, 2009 | 10:12 PM
stingraymyway
The alloy wheels aren't as expensive as their carbon fiber/mag. counter parts. Same great looks. But you won't have to take out a second morgage.
But if I could...........
Old Jun 10, 2009 | 10:16 PM
dobewillie's Avatar
dobewillie
good lookin
Old Jun 11, 2009 | 08:17 AM
Top Flight's Avatar
Top Flight
MCV does Calloway have a gallery of their customers and vehicles. I have been wanting to find a active form of Calloway modified Corvettes. I love the DD exhaust but haven't seen or herad many in my area.
Old Jun 11, 2009 | 11:08 AM
stingraymyway
Here's mine. Honker air box and DD exhaust with surround, custom painted to go with the interior.
The exhaust has a very cool idle sound, no motor boat.
Take off and full throttle is deep and powerful.
Quiet and no drone at cruising speeds. No loud cabin noise
on long trips.
Old Jun 11, 2009 | 02:39 PM
mcv's Avatar
mcv
Assortment of cars with Callaway wheels:
Old Jun 11, 2009 | 08:38 PM
stingraymyway
PM sent.
Old Jun 12, 2009 | 08:28 AM
mcv's Avatar
mcv
Check out http://www.callawayownersgroup.com/
They're a very supportive group of Callaway enthusiasts, owning everything from RPO B2K Twin Turbo Corvettes to Callaway C16's.
To Callaway Wheels
