I'm aware of what the manual recommends, but I'm asking if anyone reused their caliper pin and bracket bolts. I've been to 5 parts stores and can not find anything close. I'm alittle worried about the torque required and the possibility of stretched threads. I wanted to get the car back on the road today. I'm pondering cleaning the threads and reloctiting them.
I can't imagine that the guys tracking these cars are changing out these bolts everytime they lossen them.
Thanks in advance
the reason that GM recommends replacing them is that the new ones come with thread locker already on them. 125lbs is a lot, but not enough to stretch it.
All you have to do is clean them old off (wire brush or a threaded die) and put some loctite on yourself. I've reused mine at least a dozen times w/o any issues and only using blue loctite.
