Underdrive pulley question
Old Jun 8, 2009 | 12:21 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Underdrive pulley question
Do aftermarket underdrive pullies also underdrive the AC compressor?
Old Jun 8, 2009 | 01:04 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
If you are wondering if an underdrive pulley will keep your AC from keeping up with the hot Texas summer, the answer is no. I have a 25% udp and have had no issues with the AC. Got the pulley in the fall of 07.
Old Jun 8, 2009 | 06:00 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Some do, some do not.
SLP and Powerbond do not underdrive a/c.
ASP, and some ATI underdrive a/c by 10%.
Old Jun 8, 2009 | 08:40 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
that's what I needed to know.
Thanks.
Old Jun 8, 2009 | 01:31 PM
B-Vette's Avatar
B-Vette
Mine did and for the other problems it caused it wasn't worth doing.
Old Jun 8, 2009 | 02:28 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Interesting. I have a 25% Powerbond UDP, is there a smaller belt, close to the engine at the back of the pulley driving the a/c compressor?
Old Jun 8, 2009 | 04:24 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
I have the 25% Powerbond too.
Yes, there are 2 belts...the 4 rib belt closest to the engine drives the a/c compressor. On the Powerbond, this pulley is stock diameter, and uses the stock length belt.
The outer 6 rib belt drives all the other accessories - power steering pump, alternator, water pump. This is what's underdriven, and uses a shorter-than-stock belt.
Old Jun 8, 2009 | 06:21 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Correct. The Powerbond 25% uses a 77.5 inch belt.
Stephen
To Underdrive pulley question
