[Z06] o2 sensor extensions.
Old Jun 8, 2009 | 08:57 PM
DANZGLASS's Avatar
DANZGLASS
Default o2 sensor extensions.
bought some used lg streets so I ordered some o2 sensor extensions from LG. Said it was an 02 z06 when I orderedthem. Got them today they are square to square is this correct?
Old Jun 8, 2009 | 09:32 PM
JuicedH22's Avatar
JuicedH22
that depends, are you 'converting' the rear o2 sensors (square plug, 2 on top of 2) to use as the 'front' (and only o2 sensors?)
OR are these actual extension wires, that are retangular (4 wires in 1 row) on both ends to use factory 'front' sensors as the only sensors?
For reference, the conversion harness is only like 4 inches long, retangular on one side, and square on the other. (which is what is normally used to convert using the rear sensors as the front sensor (only sensor) placement.
OEM info:
front sensor wire length is about 6-7 inches long, with rectangular plug (single row)
rear sensor wire length is around 12-15 inches long, with square plug (2x2 rows)
With efi live and others, you turn off the rear (postcat) sensors, not the front (precat)
Old Jun 8, 2009 | 10:41 PM
DANZGLASS's Avatar
DANZGLASS
[QUOTE=JuicedH22;1570379868]that depends, are you 'converting' the rear o2 sensors (square plug, 2 on top of 2) to use as the 'front' (and only o2 sensors?)
pretty sure this was the plan.
Old Jun 8, 2009 | 11:08 PM
Blue Blood's Avatar
Blue Blood
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
[QUOTE=DANZGLASS;1570380873]
Then you've got the wrong ones. As already stated, you have wires to extend the rear, not convert the rears to the front harness.
To o2 sensor extensions.
