[Z06] Vararam Question
Old Jun 9, 2009 | 10:13 AM
HUSKER-Z's Avatar
HUSKER-Z
Default Vararam Question
Ok, put a new filter in the other day...now I'm having a b#$% of a time getting the air tube stuck back on those two prong things. Any suggestions? Don't want to break em.
Old Jun 9, 2009 | 10:35 AM
dcd58's Avatar
dcd58
are you going up to the first stop or second on the rubber part? It's the first stop, closest to the top portion of the rubber strap.
Old Jun 9, 2009 | 01:28 PM
HUSKER-Z's Avatar
HUSKER-Z
not exactly sure...are there two stops on the air tube, or on the prongs?
Old Jun 10, 2009 | 05:52 AM
dcd58's Avatar
dcd58
They are on the rubber fastners that slip into the chrome prongs on the filter housing. There is bottom "bump-out" on the rubber fastner. That is not the correct adjustment . I think it acts as a spacer. Just slip the rubber fastner over the prongs as close to the top of the rubber as possible
hope this helps you
Old Jun 10, 2009 | 04:10 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Call us at 866-507-2648 if you are still having a problem!!!! Thanks
Steve
To Vararam Question
