97 C5 LS1 upgrade question?
Old Jun 11, 2009 | 05:08 PM
FLASHGLS's Avatar
FLASHGLS
Default 97 C5 LS1 upgrade question?
I have a 97 C5 LS1, I want to know if I bold on a LS6 manifold, is it a direct fit and what can I expect in performamce?
Old Jun 11, 2009 | 05:18 PM
97C5owner's Avatar
97C5owner
Yes sir. Direct bolt on. 10-15hp gain. Great addition for the $$. You'll need the coolant retrofit pipe. Its about $15. About a 3 hour job. Change your oil pressure sending unit while you're there and save yourself a job down the road! They're notorious for going out.
Old Jun 11, 2009 | 05:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Here is a article on a "HOW TO!" swap it out with a Dyno @ the end to see the results!
http://www.ls1howto.com/index.php?article=5
Here is another article of the Compare of different manifolds for the LS series motors and their results:
http://www.tpis.com/index.php?module=2_17_06
The LS6 manifold is one of the best bolt on mods for our year Vettes, you wont regret installing it and it is pretty straight forward
Thanks,Matt
Old Jun 12, 2009 | 12:13 AM
DuronClocker's Avatar
DuronClocker
BTW, you don't have to buy any different coolant pipes. You can grind (or use pliers and snap) some ribs off the bottom of the intake to fit your stock early LS1 coolant lines. I actually prefer this method
To 97 C5 LS1 upgrade question?
