AC light
Old Jun 11, 2009 | 10:57 PM
endryck396's Avatar
endryck396
Default AC light
I new to Corvettes. I just bought a 99 coupe, I've only had it for a few days. I have an issue with my AC digital read out.
For some reason it has gone out or I somehow dimmed it to the point that I cannot read it. Is there anyway to control the digital read out brightness?
Thanks.
Old Jun 12, 2009 | 12:19 AM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
Common problem. The solder joints on some of the chip resistors in your hvac controller tend to fail and need to be resoldered. Do a search for "dim hvac" and you should find lots of reading material. You can attempt the fix yourself, or remove your controls and send the unit out to be fixed.
Old Jun 12, 2009 | 12:48 AM
endryck396's Avatar
endryck396
thanks for pointing me in the right direction
Old Jun 12, 2009 | 01:08 AM
skydive120's Avatar
skydive120
Its an easy fix if you can turn a wrench and run a solder gun. Was the first thing I posted about when I got my new 2000, there are several links on how to resolder the components, Ill post them if I can find them.
Old Jun 12, 2009 | 01:13 AM
skydive120's Avatar
skydive120
Here is the link for you---
http://forums.corvetteforum.com/c5-t...splay-fix.html
Chris
Old Jun 12, 2009 | 01:20 AM
endryck396's Avatar
endryck396
Chris,
The link did not work. Is there a typo? Thanks
Old Jun 12, 2009 | 01:22 AM
skydive120's Avatar
skydive120
Looking into it right now, dont think so,, but looking
Old Jun 12, 2009 | 01:26 AM
skydive120's Avatar
skydive120
It worked for me.
try this one
or this one.
http://forums.corvetteforum.com/c5-g...ery-dim-2.html
If that does not work let me know, ill cut and paste it all to you!
To AC light
