I'll be pulling my radiator this weekend and was wondering how much trans fluid (I have an Automatic) will I loose when I disconnect the trans cooler from the radiator.
Very little - If you feel you need to re-add some you will want to take it to a tranny shop and have them put it on a lift in order to add it
It's not like the old days, on our C5's it has to be added from underneath the Vette and added with a pump/hose It wont be much to have them do it!
Catch the spilled stuff in a container when you pull it and you'll be able best to determine if you need or want to replace it - You could also have the Tranny Shop do a filter change and then you'll be full when they add the tranny fluid with the new filter
