Dual climate display dim
Old Jun 14, 2009 | 09:21 PM
Steve's98's Avatar
Steve's98
Default Dual climate display dim
My dual climate light is dim, but when I tap on the display the light gets bright again. It will stay bright til I turn it off and then I will have to tap it again here and there. Any ideas?
Steve
Old Jun 14, 2009 | 09:23 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
You have to resolder the resistors. There are a few articles on here with howto's, or you can have it done.
Very common issue. (I will search for the articles).
Old Jun 14, 2009 | 09:25 PM
devnull's Avatar
devnull
BINGO! <--- clicky
Old Jun 14, 2009 | 09:34 PM
Steve's98's Avatar
Steve's98
Thanks, I will have to give that a try.
Old Jun 14, 2009 | 09:47 PM
MagRedConv's Avatar
MagRedConv
Check your post in Tech
Old Jun 14, 2009 | 11:57 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Basically, after thousands of heating and cooling cycles, the solder loses its conductive mojo. That's pretty much all there is to it. Resolder and you're as good as new.
Old Jun 15, 2009 | 12:51 PM
GRUNIE's Avatar
GRUNIE
Had to fix mine.
Old Jun 15, 2009 | 12:58 PM
DevilMan02's Avatar
DevilMan02
Originally Posted by devnull
BINGO! <--- clicky
Thank you. Mine has been very dim too but I didn't realize there was an actual issue. I thought it was just the way the unit is.
Old Jun 15, 2009 | 08:09 PM
jobear's Avatar
jobear
It is an easy project and most anyone can do-do a search and you should come up with something. I did mine and followed very good detailed instructions from this site.
Old Jun 15, 2009 | 09:07 PM
If you can't find the info using a search, I can send you some files if you PM me your e-mail address.
Old Jun 15, 2009 | 11:37 PM
lil vette's Avatar
lil vette
I did mine...easy fix
To Dual climate display dim
