Engine check light
Old Jun 15, 2009 | 02:43 PM
VetteRafa's Avatar
VetteRafa
Default Engine check light
So first of all.. i have a vert 2000 and i changed the H-pipe to magnaflow with high flow cats (just because the original cats went bad) and since i was doing that i put the z06 cat back. So far nothing wrong
But since i did that some times my engine check light pops and stay on for a while... then off for a while.. then on again... I have no problem with the light so the question is.
My friend told me that some cars when have the engine check light on change their fuel mapping to a "safe mode" and that makes you loose peprformance. Is that true? Does it happen to the vetts? or is all that just a legend..
Old Jun 15, 2009 | 02:48 PM
HG's Avatar
HG
Do you have the code that's set. Try here and get a code, I'm sure you'll get and answer from the forum
http://www.stengel.net/diccodes.htm
Old Jun 15, 2009 | 03:19 PM
J S Machine's Avatar
J S Machine
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17
St. Jude Knife Maker
Just post your codes here. We can help.
If it has a SES light, it has a codes or multiple codes.
To Engine check light
