Convertable rear window coming unglued ??
Old Jun 16, 2009 | 02:06 AM
gtrclive's Avatar
gtrclive
4th Gear
Default Convertable rear window coming unglued ??
My 01 Conv rear glass window has started to separate from the cloth top. It looks like There's a kind of 3M double sided tape about 1/8" thick and 3/8" wide, but it's started to ripe off....
Has anyone had this issue ? and did you manage to get some replacement tape form anywhere ?? The Local GM dealer was less than helpful (Quote "Sorry we can only sell you a new roof at $7000")...
Any advice would be nice....
Clive
Old Jun 16, 2009 | 07:03 AM
VETSTYL's Avatar
VETSTYL
Had mine reglued in Maryland for $200. Every convertible top shop that I contacted said that it couldn't be done. Dropped my car at of all things a boat reupholstery shop that morning and picked it up that afternoon. Six months later and still no sign of separation. You can also just buy a top alone. I think they go for four to five hundred and I've seen installation around five hundred.
Good luck!!
VETSTYL
Old Jun 16, 2009 | 08:57 AM
vetteman4228's Avatar
vetteman4228
Cruising
this is good site to find parts cheaphttp://car-part.com/
Old Jun 16, 2009 | 11:18 AM
gtrclive's Avatar
gtrclive
4th Gear
Good luck!!
VETSTYL
Dont surpose you could find out what Sealant they used ?? and glad to here it's still good...
Clive
Old Jun 16, 2009 | 11:34 AM
Y-Body's Avatar
Y-Body
From: Member since May 99 (Before 99 CF Crash & Burn) Georgia
There are several threads for repairing a loose convertible rear window. Here is one.
Old Jun 16, 2009 | 06:51 PM
widewheel's Avatar
widewheel
There are several threads. I fixed mine with Rhino Glue mentioned in one of them. It's gone through a hotter than he11 summer and a hard cold winter and it is still holding up. It's worth a try. You can always replace the top, but $7,000 is waaaaay too much.
Old Jun 16, 2009 | 07:34 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
$7000 for a top?? That's insane.
Old Jun 16, 2009 | 07:39 PM
dobewillie's Avatar
dobewillie
a lot of successful fixes posted from guys using gorilla glue good luck
Old Jun 16, 2009 | 07:42 PM
JMc's Avatar
JMc
Originally Posted by dobewillie
a lot of successful fixes posted from guys using Rhino glue good luck
Fixed it for ya...
Old Jun 16, 2009 | 07:44 PM
Mgunn's Avatar
Mgunn
same problem here think ill try the glue trick
Old Jun 17, 2009 | 03:59 PM
waupachino's Avatar
waupachino
Fixed mine with the recommended Rhino Glue. I believe you have to buy it on line. 1 year later it is still holding strong. Wouldn't recommend anything else. Rhino Glue works. Here is their link.
http://www.rhinoglue.com/
Old Jun 17, 2009 | 04:02 PM
ecoman's Avatar
ecoman
Glued mine had no problems
To Convertable rear window coming unglued ??
