[Z06] Need help with dic message
Old Jun 17, 2009 | 06:19 PM
yellowLPEZO6's Avatar
yellowLPEZO6
Default Need help with dic message
I have a 2003 zo6 with 8500 mi. on the clock,and about a month ago the DIC started flashing Service Traction System, Service ABS, Service Active Handling every time i start the car.
You can stop the flashing on the DIC by pushing the reset button 3 times,but the ABS, AND TRACTION CONTROL, ICON LIGHTS on the instrument panel stay on while driving.
Has this happened to anyone else? and what was done to correct the problem?Also could someone tell me how to check for trouble codes using the DIC.
THANKS SO MUCH IN ADVANCE, AND THANK GOD THE CORVETTE FORUM EXISTS WITH ALL OF ITS HELPFULL MEMBERS.
yellow lpe zo6
Old Jun 17, 2009 | 06:39 PM
dcd58's Avatar
dcd58
If you go into diagnostic mode you can clear them. If they keep coming back on, you most likely need to get the car serviced. It happened to me and I got it fixed with my extended warranty
Old Jun 17, 2009 | 06:43 PM
bob guzzy's Avatar
bob guzzy
Take the car and have the codes cleared, and see if it comes back, if it comes back there may be some type of a problem, it the cars feels right and drives right you just may have a computer glitch.
Just reseting it does nothing, it will just keep comming back untill it's cleared.
Old Jun 17, 2009 | 06:48 PM
jstrime's Avatar
jstrime
Check those stupid little grounding plugs under the hood. Both of mine went bad and I just cut them out and put good ole ring terminals on them and bolted them back to the frame. Problem solved !!!
Old Jun 17, 2009 | 09:27 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
yellow lpe zo6
It happened to my 02 Z. Take it into the dealer, they had to replace the entire unit, cost is about $3000.00, but should be fixed under warranty.
Old Jun 17, 2009 | 10:42 PM
Slow Z06's Avatar
Slow Z06
clear the codes and charge your battery. See if they go away
Oh yea, if you are getting a message on your dic, you should see a doctor
:roflmao:
Old Jun 17, 2009 | 11:02 PM
bartsky's Avatar
bartsky
:roflmao:
Too funny...
Old Jun 18, 2009 | 11:38 AM
2K3Z06's Avatar
2K3Z06
From: KADS- If it has wings or an engine, I can break it. Dallas TX
Check the ground, if not that, then its probably the ABS module.
Old Jun 18, 2009 | 12:25 PM
Drewstein's Avatar
Drewstein
If it is the EBCM you should go through ABS fixer as it's $150 vs the above quote.
Old Jun 18, 2009 | 07:29 PM
JUSTAKAR's Avatar
JUSTAKAR
Default codes
First / get the code...determine plan of action based on the code you get.
The codes can be reset by you on the DIC BUT these are codes which will determine the repair..which could be anything from a wheel bearing sensor to a ECBM failure so get the codes and take it from there.
Regards Ian
Old Jun 18, 2009 | 07:53 PM
PA Z06's Avatar
PA Z06
sounds like ebcm
Old Jun 18, 2009 | 11:47 PM
tlove32's Avatar
tlove32
Get those codes and post them. I got the same messages on the DIC - codes 1287 and 1288.....steering wheel position sensor. Had it replaced under warranty....no more messages or code
Old Jun 18, 2009 | 11:53 PM
wildwall's Avatar
wildwall
Common problem- no big deal:
http://www.absfixer.com/
Old Jun 22, 2009 | 05:37 PM
Bill Dearborn's Avatar
Bill Dearborn
It is a common problem, however, just repairing or replacing the EBCM may not solve the issue. The Brake Pressure Modulator Valve (BPMV) may be the culprit that caused the EBCM to fail. If so it will need to be replaced during the repair or the new/repaired EBCM will fail again. The BPMV cost is what drives the dealer repair into the $3K range.
Bill
To Need help with dic message
