I just about ready to order a new set of rims for my '01 Z. 9.5x 18 front, 11 or 12 x19 rear.Would you go oem 11" rear or upgrade to 12", any clearance issues? Thanks
12's won't fit without fender flares or a mini-tub kit. 11's will give you plenty of tire to fit in the stock fender wells...you can run 315's on 11" rims and the side walls won't roll up like they do on the factory 10.5's.
No problem. It will be personal preference as to what width you run on the 11" wide. A 295 can look stretched, so most likely a 305 or 315; it just depends on the look that you like, and the actual brand of tire will have something to do with that as well. Some brands of tires are just wider/narrower than others regardless if they all list the same size on the sidewalls.
John @ AutoBuff is recommending Michelin PS2's, 305/30zr19 rear and 165/40zr18's front. I'm going to order the IForged TE-10's in anthracite tomorrow. Should look pretty trick on my Quicksilver Metallic '01. Thanks again for your help.
Lol!!! I just ordered these today. Going on an 03 black z. I'm going with 305/30r19 and 275/35r18 nitto invos. Shoot me some pics of ur ride when you get them on.
