colom lock message HELP
Old Jun 18, 2009 | 09:57 PM
Lvnspeed's Avatar
Lvnspeed
Default colom lock message HELP
Today I got the colom lock message and yes the battery is charged fully. The colom is locked on top of that now for some reason neither one of my keys will turn the ingition switch either. My car is stuck at work with no way of getting it home to work on it any suggestions for getting home beside a tow truck?
Old Jun 19, 2009 | 09:05 AM
Lvnspeed's Avatar
Lvnspeed
Ttt
Old Jun 19, 2009 | 10:32 AM
tremor1's Avatar
tremor1
When you get it mobile again install a column lock bypass and never worry about it again.
Old Jun 19, 2009 | 07:30 PM
Lvnspeed's Avatar
Lvnspeed
The technique lined above wont work until I can get the key to turn I am going to remone the ing. switch.
Can I get a lock smith to fix the the lock or do I need to get a new one from GM? If I get a new one from GM can the key it to the same key I have? Do they need the car to do it or can I just bring them the lock cylinder? Does the lock cylinder or the key have the VIN programed into it?
Old Jun 24, 2009 | 07:48 PM
Lvnspeed's Avatar
Lvnspeed
Ok I got ther entire ignition swith out but I cant remove the lock cylinder from thje switch. While I was messing with it I managed to seperate the switch from the lock cylinder but the springs and pins fell out....
Can I just swap the complete ignition switch and key?
Old Jun 24, 2009 | 08:11 PM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Clean the resistor on your key and fix both problems. A dirty resistor will not allow you to turn the key and also give a column lock message.
Old Jun 24, 2009 | 08:21 PM
Lvnspeed's Avatar
Lvnspeed
tried that too no go.
Old Jun 25, 2009 | 08:42 AM
Torch Red 02's Avatar
Torch Red 02
Once you are un-stuck, even if you've had the recall work performed, for piece of mind it's best to install the column lock bypass device.
Old Jun 25, 2009 | 09:16 AM
Lvnspeed's Avatar
Lvnspeed
Will do I first need to get a ignition switch
Old Jun 25, 2009 | 09:45 AM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
At this point I think your best course of action is to have it towed to the GM dealership before you do any more damage. This problem is rarely the ignition switch. By removing it and taking it apart, you just cost yourself more money.
Old Jun 25, 2009 | 11:58 AM
SLWRNU's Avatar
SLWRNU
Old Jun 25, 2009 | 01:25 PM
Lvnspeed's Avatar
Lvnspeed
too late the ingition switch is already out of the car. I have a quote from my local dealer for a new lock cylinder and ignition switch. Just hoping I could find someone on here who has a complete unit I could buy.
Are the VIN's programmed in to the keys/switch somehow?
Old Jun 25, 2009 | 03:10 PM
ChromeC5's Avatar
ChromeC5
As far as I know, the VIN is not encoded in the key, the 'chip' in the key is just a resistor that the computer reads to make sure it is the correct resistance. I think there are 15 different resistors that could be used in the key. Your dealership will know which one it is. As for the column being locked, once the ignition is fixed, 8VETTE7 or I can help you with getting the column lock message figured out as 8VETTE7 just helped me diagnose mine. (THANKS AGAIN).
Old Jun 25, 2009 | 08:14 PM
Lvnspeed's Avatar
Lvnspeed
Thanks CHROME
Old Jun 30, 2009 | 09:35 AM
Lvnspeed's Avatar
Lvnspeed
Well got the new Ign. switch in but now everything Electrical is freeked out and the car wont start. I am going to pull it back apart tonigt and see whats up.
No I am not going to take it to the dealer. I will figure it or at least get some advice from forum members and hopefully narrow it down.
Old Jul 1, 2009 | 06:22 PM
Lvnspeed's Avatar
Lvnspeed
any ideas?
Old Jul 1, 2009 | 09:04 PM
Lvnspeed's Avatar
Lvnspeed
OK the freaked out condition is resolved had the 2 plugs on the ingition switch swapped. Now when you put the key in everthing acts normal but when you go to start it everthing goes dead. Like the clutch is not puched in. The clutch switch worked fine before the switch failure any ideas?
To colom lock message HELP
Old Jul 1, 2009 | 10:41 PM
cor28vettes's Avatar
cor28vettes
2 suggestions -
1. Click SEARCH and enter
column lock
2. Click the STICKY on top of C5 page titled
Weights, measurements......
Old Jul 1, 2009 | 11:37 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Did you get the column unlocked? I did not see where you got that fixed yet.
Old Jul 1, 2009 | 11:38 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Originally Posted by pearlwhite
2 suggestions -
column lock
There is also info on the C5 Tech page about the column lock
