Battery replacement.......
Old Jun 19, 2009 | 06:45 PM
corvett66's Avatar
corvett66
Default Battery replacement.......
The original battery (Sept. 2002) in my 2003 AE finally bit the dust yesterday. I replaced it today, but I noticed that some of the readouts on my DIC don't have any numbers, like the tire pressures.
Is there any kind of procedure you have to follow after replacing a battery? I couldn't find anything in the owners manual or service manuals. Do I have to go through and re-learn all the tire pressure sensors? Thanks.
Old Jun 19, 2009 | 07:58 PM
my6thvette's Avatar
my6thvette
The only thing I ever had to do was re-sinc the key fobs.
Old Jun 19, 2009 | 10:32 PM
ness5353's Avatar
ness5353
changed the original in my '01 a couple of months ago...
no problem....nothing changed, nothing to reset.
Rod
Old Jun 19, 2009 | 11:02 PM
8VETTE7's Avatar
8VETTE7
The only issue you MIGHT run into is if you have enabled the radio theft lok feature. If so then you will need to know the pass code that you set to unlock the radio after replacing the battery. Other than that there should be nothing to do/worry about.
To Battery replacement.......
