window switch
Old Jun 21, 2009 | 08:13 PM
tarheeljww's Avatar
tarheeljww
Default window switch
I have an 02 vert, and my passager window switch is dead........anybody else have this problem? is it common? I can change out the switch for 75.00, but don't want to just start changing out parts.....
How would I trouble shoot this?
Thanks for any info...
Jw
Old Jun 21, 2009 | 09:25 PM
Bakersfield's Avatar
Bakersfield
Start by reading this.
http://forums.corvetteforum.com/c5-g...w-problem.html
I have yet to see a bad switch so look further before you buy one.
Old Jun 21, 2009 | 10:26 PM
tarheeljww's Avatar
tarheeljww
Thanks for your reply bakersville......
The damnest thing, just went out and when I got in the car, the window worked.....
When it didn't, the whole switch was dead, as in no back light, or anything working.....would that be a relay?? Even when the doorlocks were out too..??
Thanks for your help...
Jw
Old Jun 22, 2009 | 03:52 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Check the connector at the back of the switch. pry the switch out from the top.
Old Jun 22, 2009 | 02:31 PM
Bakersfield
And, check the wiring inside the rubber boot at the door hinge. It is all explained in the link I gave you. Clean every connector and even if it looks clean, spray it anyway with some contact cleaner and then reconnect it.
Old Jun 22, 2009 | 02:50 PM
tstar's Avatar
tstar
Sorry, I didn't even check the link B... I would think that without lights or anything it would be the connector at the back of the switch...
I'm bowing out, you're in excellent hands!
Tim
To window switch
