braided brake lines ?
Old Jun 22, 2009 | 07:52 PM
CheckeredFlag's Avatar
CheckeredFlag
Default braided brake lines ?
I've heard they really firm up the brakes over rubber
Have you added them ?
Old Jun 22, 2009 | 08:12 PM
LEANDRO's Avatar
LEANDRO
They seemed to be better but I also put in a brake bias spring also. I think there were worth the 100.00. I got the Doug Rippie spring. Its only a couple of buck, easy to install.
Old Jun 22, 2009 | 08:58 PM
mountainbiker2's Avatar
mountainbiker2
There's no difference. I thought maybe there was at first, but after 10 stops you what no the difference.
Steve
Old Jun 22, 2009 | 10:13 PM
Z06_Joe's Avatar
Z06_Joe
St. Jude Donor '09-'10
This was the first upgared i did on my car before I upgraded to a Stoptech BBK. I purchased mine from Doug Rippie Motorsports and I did notice a firmer pedal under braking. Its a $100 mod and Doug has the best kit IMHO.
Joe
Old Jun 22, 2009 | 11:58 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
In my mind, the only braided lines to have are the Goodridge Brake lines. They are a part of the Brembo kits.
I feel that they do firm up the pedal feel, and they are certainly more resistant to the ravages of time and the elements compared to the stock lines.
Years ago, there was an issue with some of the braided lines transmitting static electricity and blowing the wheel speed sensors, the only ones that never caused that issue were the Goodridge.....they are worth the extra money if you are going to do this upgrade.
Old Jun 23, 2009 | 12:09 AM
ChromeC5's Avatar
ChromeC5
Are the hubs/spindles seriously isolated from the rest of the car where braided brake lines can transmit static shock? I imagine there would be no static build up between the hubs/spindles and car as the hubs/spindle assembly is connected to the rest of the car through the a arms, or steering linkage, or sway bars. If not, that is cool. I had no idea! I have not looked under the car to see. That is some neat info.
Old Jun 23, 2009 | 12:28 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Giving cosnideration to this in my 97. (original lines) ...trying to set it up so that i can have the calipers powdercoated and back by the time the lines arrive.
Old Jun 23, 2009 | 01:22 AM
Dave Sweatt's Avatar
Dave Sweatt
You really notice them the most when you get the brakes real hot like a track day or such. The lines and a good racing brake fluid helps with brake fade. Assuming you've already upped your pads too.
Old Jun 23, 2009 | 09:43 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
If you want to firm up your brakes get a quality brake pad,dot 4 fluid and goodridge lines.
Old Jun 23, 2009 | 09:47 AM
kg54trains's Avatar
kg54trains
If only the upgrade is to brake lines in will not be a big diff on street drive. Look to a upgraded brake pad-Hawk Pads-$$, or adding new rotors with increased pistons-$$$$ to see more impact on the pedal experience.
Old Jun 23, 2009 | 09:49 AM
Dominic Toretto's Avatar
Dominic Toretto
I'm either going with Stoptech or Goodrich braided lines
-Alex
Old Jun 23, 2009 | 01:10 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Our brake lines are made by Goodridge to our specs. We no longer use the Banjo style fittings. We use a straight adapter going into the caliper with a -3 90 degree fitting into the adapter. You will find this style connection on just about every racecar on the track. They are DOT approved and offer years of dependable service. The pedal feel will be most improved in high mileage, or heavy used stock brake lines.
Please note, we have had our lines on AP, Brembo, Stoptech, Wilwood, PFC, and all other brands of caliper. Our "kit" fits the stock line, please get a hold of me if you have anything different
Randy
Old Jun 23, 2009 | 03:56 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Randy: do you have a e-file of the installation procedure so i know what I'm about to Dive into?
To braided brake lines ?
