Radiator Troubles
Old Jun 23, 2009 | 01:47 AM
dman7441's Avatar
dman7441
Default Radiator Troubles
So I'm in the middle of swapping a cam and putting new heads and springs and the whole shebang on, have everything torn apart labeled off in the corner ... and i have to take a break to go to illinois. While I'm away my roomate decided to go out on his jet skis which is fine but he had to move my radiator and well ... he fails at life and now i have a huge fricking hole in it ... should i try to get it repaired, get a oem replacement ... or just go all out since I might and get a new one with an EOC and save myself the hassle of pulling it later. Opinions advice ? anything is appreciated.
Old Jun 23, 2009 | 09:33 AM
Blown427conv's Avatar
Blown427conv
Get a new aftermarket radiator, $200. These are not worth fixing in my experience unless the hole is only in one plastic tank, then maybe...
Old Jun 23, 2009 | 09:38 AM
8VETTE7's Avatar
8VETTE7
Get a new one. Repairing holes in the aluminum core is an ifffy proposition at best.
Old Jun 23, 2009 | 10:13 PM
robsc501's Avatar
robsc501
Hi There:
Rap the jet ski around his fat head & buy a after market radiator.
robsc501
Old Jun 24, 2009 | 07:37 PM
dman7441's Avatar
dman7441
Hah, yeah i think i took it better than i should have. Only because i kinda wanted to upgrade anyways since eventually i'll most likely have to out of necessity ... i thought about getting a used one but most likely i'm getting someone elses that just got repaired ... so meh.
Old Jun 24, 2009 | 07:47 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Have your wonderful room mate buy you a new one... Simple.
To Radiator Troubles
