I'm getting ready to purchase 18 x 9.5 and 19 x 11" rims, I have someone willing to sell me some slightly used tires, 285/30/18 and 295/35/19. Will I have any problems mounting these on a C5 (rubbing, etc.)
Thanks for any help in advance
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The 9.5" wide wheel is the minimum recommended width for the 285-30x18 according to the chart that I consulted. You should be okay on these sizes, assuming you have the correct backspacing and offsets on the wheels.
Bolt Pattern: 5x4.75
Offset: +64 +54
Backspacing: 8.52 7.38
Would this be the correct offset and backspacing.
thanks for your help
I'm also getting ready to order tires for 9.5x18 and 11x19 setup. I'll be getting 265/35/18 front and 305/30/19 rear. I was told by another forum member that the OEM specs are : Front 54mm offset, 7.375" backspace. Rear: 58mm offset, 8.033" backspace. Thats alittle different from vett.mix's post. I told the folks at IForge that I wanted an OEM setup on my '01. They assured me the set up wouldn't rub or sit out side of the fenders.
