Average Oil Pressure ?
Old Jun 25, 2009 | 01:29 PM
killain's Avatar
killain
Oldtimer
Default Average Oil Pressure ?
What kind of oil pressures do you folks have when your engine is heated up and at say 35 MPH and what is it at idle? I was wondering what the average is with a LS-1 350 ?
Old Jun 25, 2009 | 01:42 PM
JCamaro's Avatar
JCamaro
Idle 28 PSI hot hot hot, Over 50PSI @ 4000rpm
Idle can be as low as 14PSI according some posts I've seen here, I'd say 26-30 PSI is normal for hot idle, and @ High RPM is should be well over 40 PSI, search in Tech there are many threads about this.
Old Jun 25, 2009 | 02:21 PM
TEXHAWK0's Avatar
TEXHAWK0
When my oil temp. is above 160 degrees or so, I never see less than 33-35 psi, and it increases with RPM.
Hot here today too. My oil temp got up to 208, and my oil pressure was still 32 at idle.
Valvoline Synpower 10W30 oil.
Old Jun 25, 2009 | 03:19 PM
ChromeC5's Avatar
ChromeC5
Mine is at 80psi, then 0psi, then 80 for a long time then, 0...did I mention that oil pressure sensor is broken? hahaha. Before it went, it was always in the 30-40 range.
Old Jun 25, 2009 | 04:29 PM
TPA Z06's Avatar
TPA Z06
Idle I'm around 38 - 40 psi, but I've seen 60+ when putting my foot into it.
Old Jun 25, 2009 | 04:32 PM
bucwheat's Avatar
bucwheat
Around 40
Old Jun 25, 2009 | 04:41 PM
diyguy's Avatar
diyguy
Average cold start up idle 40 - 50
Cold at 3500 RPM 60
When at op temp idle 30
At 3500 warm 40
Old Jun 25, 2009 | 05:08 PM
ksvette74's Avatar
ksvette74
I beleive im 28-30 when warm and at idle. At cruise speed, im at about 40-42. Goes up when your right foot goes down.
Old Jun 25, 2009 | 06:11 PM
ksvette74's Avatar
ksvette74
just checked today. It is very hot, so my oil temp was at 216. In park at idle was 23psi. Going down the road was at about 40 psi. If I pushed it down enough to downshift it went up to over 50 psi pretty quick ( I did not run it to redline, just a little downshift). I beleive idle out of park is higher as everythign is engaged, hope this answere your questions!
To Average Oil Pressure ?
