[Z06] So, my clutch died...
Old Jun 26, 2009 | 11:26 PM
Had20z's Avatar
Had20z
Default So, my clutch died...
Hey guys, well .... the track was bad to me tonight, im about 85% sure i killed my clutch....
So, In yalls thoughts...who makes the best clutch out there?
Mike
Old Jun 26, 2009 | 11:32 PM
thehammer69's Avatar
thehammer69
Mike
let me guess...your clutch pedal is sticking to the floor? If so, do a search on sticking clutch pedal and you will find your fix without replacing the clutch.
Old Jun 26, 2009 | 11:38 PM
Had20z's Avatar
Had20z
Negative...its not doing that.
Old Jun 27, 2009 | 06:05 AM
Ranger's Avatar
Ranger
What were the circumstances and symptoms that lead you to believe the clutch is toast?
Ranger
Old Jun 27, 2009 | 11:32 AM
Had20z's Avatar
Had20z
So, we were at the track last night. I made a couple of passes and i was sitting in the stageing lanes... going threw the gears and it would let me go into third.
during my race, it grinded going into third, but i forced it in. and since then it grinds going into 3rd and 4th....
it might not be the clutch.....maybe the syncros going into 3rd? idk?
Old Jun 27, 2009 | 11:45 AM
bob guzzy's Avatar
bob guzzy
As long as the clutch is not slipping it's not toast, sounds like more of a trans problem than a clutch problem to me.
Maybe with the heat and the heat buidup from raceing the trans fluid is cooked, I would change the trans fluid, it won't cure the problem but it might help the trans last a little longer with dialy use.
Old Jun 27, 2009 | 01:05 PM
Had20z's Avatar
Had20z
it is slipping....a little....but after driving it just now, and inspecting the fluid. I wanna change the fluid first. and then go from there....
its still grinding going into third. but only when there is a "load" on it...but its still really sloppy...?
Old Jun 27, 2009 | 06:56 PM
Ranger's Avatar
Ranger
I shot you a PM with my cell.
Ranger
Old Jun 28, 2009 | 11:40 AM
juice12's Avatar
juice12
grinding going into 3rd and you FORCED it in? I would say you bent a shift fork or have a synchro going out. My clutch was toast and it was hard to get into 1st and reverse but not the other gears.
Old Jun 28, 2009 | 01:05 PM
ov666's Avatar
ov666
i have been told monster is the best one on the market right now. when ii had to due mine it was spec but they changesomethimg now and there not holding up.
Old Jun 28, 2009 | 05:07 PM
Had20z's Avatar
Had20z
So after my talk with Ranger this morning I started to replace my clutch fluid.
The first few times I changed it out it was still dirty. Now the fluid looks fairly clean...
but
The grinding going into third is still there...
I wanna replace the fluid a few more times and then go from there with it...
Thanks Ranger for the talk this morning!
Mike
Old Jun 28, 2009 | 05:36 PM
juice12's Avatar
juice12
its not going to stop grinding cause its pry got nothing to do with the clutch. Hell I could shift mine with out the clutch and it wouldn't grind if you did it right. And while I agree that keeping you fluid fresh helps, if the clutch is shot, its shot, and the only solution is a better one.
Old Jun 28, 2009 | 05:50 PM
Had20z's Avatar
Had20z
Mike
Old Jun 28, 2009 | 05:56 PM
Ranger's Avatar
Ranger
but
Mike
Good to meet you, Mike.
Be persistent with the fluid. If it had never been changed, ought to take 10-20 swaps with interspersed driving to get the fluid back to the same color as coming out of the bottle. Then, it's on to next steps.
For all.
If the clutch hydraulics are malfunctioning, there is often an incomplete release of the clutch even when the pedal is fully depressed. That's can be especially the case during fast shifts. If the seals in the master are hanging, the nominal force needed for the actuator to function fully is compromised.
That's why getting the clutch fluid thoroughly clean is a necessary first-step. If that doesn't solve the grinds, then swapping the master cylinder is the next step. Given the history of the car and its mileage, wouldn't seem likely that the clutch (FW, disc, PP) elements are bad. Clutch hydraulics (fluid or master cylinder) are the usual culprits.
It may turn out that the issue is in the tranny. But that's not the place to start except by those willing to have their wallets pillaged by dealers or shops.
Ranger
Old Jun 28, 2009 | 06:52 PM
juice12's Avatar
juice12
I agree start with the cheap stuff 1st, but why would it just grind going into 3rd? Is the car hard to get into 1st gear or reverse? I did the fluid thing on mine, and while I think it did help, my clutch just wasn't (oz700 tex) strong enough for 700 rwhp. I would recommend the clutch for lesser amounts as it bites hard and has a nice peddle feel and no chatter. I hope to hell the fluid swap fixes your problem because fixing these things is hell on the old checking account lol
Old Jun 28, 2009 | 06:55 PM
AlwaysInBoost's Avatar
AlwaysInBoost
was the car off when you were rowing threw the gears? if so the clutch isn't your problem.
Old Jun 28, 2009 | 07:03 PM
Had20z's Avatar
Had20z
all the other gears are fine, doesnt grind and still feels really crisp going into them...
im on my 6th fluid change right now, after i drove it just now it went into third with no grinding and it felt firm....but as soon as i went into it again the grinding came back....
the car was on...
no matter what, i have learned alot in the past few days about the clutch systems these cars have. Its been a learning experience for me...might be an expensive experience..but non the less a learning one... :o
To So, my clutch died...
Old Jun 28, 2009 | 07:04 PM
Ranger's Avatar
Ranger
New-to-him car with 40K miles; basically stock power. Original clutch with original fluid.
Tranny with steel shift forks is new with less than 2K miles.
Ranger
Old Jun 28, 2009 | 07:23 PM
Ranger's Avatar
Ranger
Suggest easy driving between fluid changes. No fast or strong shifts.
The fluid swaps will help disgorge air from the hydraulics and give a reliable, consistent engagement point.
Where is the clutch engagement point? And does the engagement point change after the car is driven?
Ranger
Old Jun 28, 2009 | 10:46 PM
juice12's Avatar
juice12
well I would keep doing the flushes if it was better for a shift or two. Mine never ground into 3rd but was hard to get into gear with the car running. The fluid flushes would make it better for a bit, and I never felt the clutch really slip but when rippie took it apart it was gone. The fluid is cheap so keep doing it like ranger says, but I have a feeling you have a new clutch in your future or at the very least some hydraulics. I know the new monster clutch is the clutch of the week right now, but if you are planning on alot of power in the future, spend the big money once and get a clutch that you can grow into.
