How to get into a Vette
Old Jun 27, 2009 | 12:29 AM
PlasticCar's Avatar
PlasticCar
Default How to get into a Vette
The other day there was a thread about a member ordering new seat skins and foam. One of the posts mentioned that the foam was probably broken down because the member didn't use the proper way to get into his C5. I could only come up with butt first and right foot then your butt and both methods caused you to slide over the side bolsters. Anybody have any other ways? Not counting taking the top off and climbing in from above.
Old Jun 27, 2009 | 12:59 AM
The NNIAL8R's Avatar
The NNIAL8R
St. Jude Donor '11,'13
"I voluntarily took 60 days off from OT"
Open door....stand 90 degrees to car facing away from door opening...sit down..swing right leg in, then left leg in....Buckle up....VROOOOOOOOOOOOOM!!!
Old Jun 27, 2009 | 01:03 AM
ChromeC5's Avatar
ChromeC5
don't forget to make the grunt noise as you're squatting down to get in.
Old Jun 27, 2009 | 01:09 AM
corvettepete's Avatar
corvettepete
Depending on how my back is doing at the time, some times it can be an "ahhhh s#*t" instead of the grunt.
Old Jun 27, 2009 | 01:12 AM
ZO6Bear's Avatar
ZO6Bear
Are people really having trouble getting into c5s? Wow. I would try doing some toe touchies every now and again.
I've thought about it for a little bit now. I stand facing the front of the car and just kinda bend down and I'm in. Don't really see how getting in could do much damage.
My guess would be a large sized category 3 squirmer could do some major cover and foam damage.
Old Jun 27, 2009 | 01:24 AM
itzza427's Avatar
itzza427
WELLLL,,I must admit at my age it may NOT be the most graceful entry,,but it doesn't seem to be doing any harm to the seat!! It often involves a slight plop for about the last 3-4 inches!! At 6'2" and 62 years of age it ain't always easy to be graceful,,especially if somebody parks a little too close !!
Old Jun 27, 2009 | 07:24 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Is this really a thread
I do a Dukes of HAZARD slide accross hood and dive through window - Ohh make sure window is open (OUCH )
Thanks,Matt
Old Jun 27, 2009 | 07:28 AM
Lancejoker's Avatar
Lancejoker
Matt,I used to jokingly do the Dukes of Hazzard hood slide. Then came the day I had a pair of jeans on and a rivet just happened to catch the right spot and left a big scratch on my brothers hood.
Old Jun 27, 2009 | 10:58 AM
Old Rotor Head's Avatar
Old Rotor Head
??????????? I don't get in I put it on, right foot in, butt in seat, left foot in,,,,,great abs workout.
Old Jun 27, 2009 | 11:06 AM
greenc5's Avatar
greenc5
fat guys shouldn't own vettes? uh oh. How about old fat guys? Have to admit, getting in AND OUT are a bit of a challenge, but I manage it. It still feels good when I'm in it.
Old Jun 27, 2009 | 11:28 AM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
That sounds familiar, "FOR" me!
Old Jun 27, 2009 | 12:25 PM
madmatt9471
You're nuts man!
I'd never slide accross the Vette hood
Thanks,Matt
Old Jun 27, 2009 | 12:41 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
You think gettin' in and out of a C5 is tough. Try a C4!!!
Friend of mine is selling his and shopping for a C5 for this very reason.
Old Jun 27, 2009 | 12:43 PM
ericshu's Avatar
ericshu
I suspect some have not seen their toes in years
I have rods in my back and can get in by putting my a$$ first!!!
Old Jun 27, 2009 | 01:55 PM
Blown427conv's Avatar
Blown427conv
I get tired of the seat and wheel moving away from each other everytime I remove the key. Need to read the manual on how to defeat this operation. Have to push the dang memory 1 button just to be able to press the clutch pedal to the floor.
Old Jun 27, 2009 | 02:00 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
My only problem is that I park the Vette as far over from my other car in my garage to reduce potential door dings, etc. As a result, I have little room to open the Vette driver's door against the wall so I sometimes tend to fall into the Vette more than sitting down.
Note - not a body mass issue, just a logistics issue.
Old Jun 27, 2009 | 02:05 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
Go through the options on the DIC. It's in there. I like it because it does make it easier to get in / out when the seat goes all the way back.
To How to get into a Vette
Old Jun 27, 2009 | 02:19 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
All you do in options is turn easy entry off, Something like that.
Old Jun 27, 2009 | 02:30 PM
napacruzerc5's Avatar
napacruzerc5
Even worse when your vette is lowered!!!
BTW Try not to use the steering wheel as an aid to getting in or out as the pressure put on it may contribute to the column lock problem.
Old Jun 27, 2009 | 05:21 PM
booker5m's Avatar
booker5m
Devilman I am not fat I am 6' and 170lbs but 2 back ops and still have 4 blowout disk. Would like to see how you get in a Vette in my shape dumb butt.
