Gas gauge malfunction??
Old Jun 27, 2009 | 01:51 AM
versatile's Avatar
versatile
Default Gas gauge malfunction??
First of all I have a 2002 C5 with 31,000km ( about 20,000 miles ) I have noticed on the last 4 tank fulls that the gas gauge seems accurate until I reach about 1/3 of a tank then.......................EMPTY!
When I fill the tank from that point it varies as to how much gas it will take.
I know of gas gauge problems with these cars but I am not familiar with these particular symtoms.
Any insight??
Old Jun 27, 2009 | 02:10 AM
Irony's Avatar
Irony
Do the following at least twice
* Add one can of seafoam to a tank of gas
Old Jun 27, 2009 | 02:21 AM
Z06ster's Avatar
Z06ster
Any insight??
Plenty of insight here my friend....
This problem is caused by corroded fuel sensors that are part of the fuel sending unit assemblies. The C5 has two gas tanks so there are a total of two fuel sending unit assemblies. The fuel sensor part is an electrical arm that goes against a contact. The position of the arm is modulated by the fuel level in the tank. Incidently, GM does have a TSB (Technical Service Bulletin) on this.
Many people here will state that adding Sea Foam and Techron abates this problem. I have always been doubtful of this claim as it never worked for me. I ultimately replaced my fuel sending units and the problem went away.
I have a nice picture of the corroded fuel sensor... when I find it, I will be back and post it here.
Matt
PS: I've been in Victoria, BC this week on a business trip. Nice place... don't know it that's near you. Headed back to LA tomorrow.
Old Jun 27, 2009 | 03:02 AM
02*C5's Avatar
02*C5
I have been having the same issue for about 6 months and you can add all the additives you want but like it was said before ultimately you'll have to change that unit out.
Old Jun 27, 2009 | 05:41 AM
homewrecker's Avatar
homewrecker
I had the gas gauge problem myself. Even on a full tank it never went past the half way mark. Started using Chevron Supreme with techron and added only one bottle of techron - my gas guage has been operating normally for a year now
Old Jun 27, 2009 | 07:00 AM
AntsSilverC5's Avatar
AntsSilverC5
I strongly recommend you give that attention ASAP. I had the same type of issue with my vette not too long after I got it, and it led to the one time I've owned my car leaving me stranded.
Basically, something happened where I ran it too low with fuel (the sending units are cooled by fuel?), and the fuel sending unit fried or something. (car wouldn't start- no gas sent to motor) I had them replaced and its been fine ever since. Dont get stuck!! Take care of this before it has a chance do the same to you. Goodluck -Anthony
Old Jun 27, 2009 | 10:33 AM
02MillenniumVette's Avatar
02MillenniumVette
As others said, use a bottle of Techron or Seafoam and that should fix the problem. If you replace them then its just going to happen again eventually and its very expensive to replace them.
Old Jun 27, 2009 | 10:52 AM
versatile's Avatar
versatile
The only fuel I have ever used is Chevron Supreme with Techron.
I will try the seafoam thing and see if it helps
Old Jun 27, 2009 | 10:58 AM
holterhouse's Avatar
holterhouse
Tried techron/seafoam with no results. Dealer repair was $1400.00
Old Jun 27, 2009 | 11:18 AM
LoudassZ's Avatar
LoudassZ
St. Jude Donor '10
Iv had the same problem for a year. It happened 3 days after I purchased my car. Even after buying an extended warranty the dealer refused to fix it and was going to charge me over a thousand dollars to fix. I returned the warranty after 4 days of having it. Mine starts off a quarter low after a full fill and only after I fill does it fluctuate. Sometimes it will go to E and say I have no fuel. But it comes back up after a little driving. Id rather spend the thousand on fun stuff so I just set my trip meter after a fill
Old Jun 27, 2009 | 11:36 AM
ChromeC5's Avatar
ChromeC5
Mine use to drop to E around a third of a tank last year, did a couple cans of Seafoam and it worked normally a couple tanks after that. Now, it will just reads E after I start it, and it does not matter where the level is, however, it does come back to read the fuel level (or sometimes half the fuel level) after 5 minutes of driving. There are fixes on the forum that do not cost an arm and a leg, however, you have to be mechanically inclined to do the repairs yourself.
Old Jun 27, 2009 | 01:07 PM
Rapid Fred's Avatar
Rapid Fred
It seems timing is of the essence for you -- the Techron fix worked for me and a number of other posters so no reason to be skeptical. But, it does not work for everybody and the most likely reason is once the corrosion goes too far no amount of additives will fix the senders.
So do the Techron RIGHT NOW and do it for 3 tankfuls. It's a cheap experiment. If that does not work, you have the choice of using your trip odometer or replacing the senders...
Old Jun 27, 2009 | 05:16 PM
philadd's Avatar
philadd
My gas guage only malfunctions after filling the tank. It goes to "E" and stays there for about 10 minutes. Then it pops up to usually around 3/4 tank and very, very slowly creeps towards "F". It'll then drop suddenly back down to "E" and stay there for a few minutes. When it pops back up it'll go to a slightly higher position than before. It goes back and for like this for the next 30 minutes or so until it finally reaches the correct position at or near "F".
I buy nothing but Chevron, and I have tried multiple bottles of Techron with no improvement. I'm currently trying a couple cans of Seafoam, and although it's helped a little after the first can, the problem still exists.
It seems like it's a hit or miss when it comes to using bottles of Techron or Seafoam to cure gas guage woes. I agree with Argent C5, in that it's probably related to how badly the sensors are corroded.
Old Jun 27, 2009 | 06:44 PM
Hopefully the Techron will do the job for you - replacing the sending units is not cheap.
Old Jun 27, 2009 | 07:31 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
I've noticed that if my gauge moves to full slowly after filling up adding Techron fixes right away. Leads me to believe it does help keep the unit clean and working correctly.
Old Jun 27, 2009 | 08:36 PM
VetteDriven's Avatar
VetteDriven
SeaFoam works. As Micky Dolenz would say. Im a Believer.
Old Jun 27, 2009 | 09:52 PM
bucwheat's Avatar
bucwheat
Better than Techron by a ton. It may take two bottles but it will fix the problem.
To Gas gauge malfunction??
Old Jul 20, 2009 | 10:09 AM
ben4981's Avatar
ben4981
3rd Gear
You are describing the same problem my 03 has. what did the dealer say would be the fix? maine has been in the shop 6 times w.o any results. they have replaced 1 tank sensor and the computer.
Old Jul 20, 2009 | 10:22 AM
bucwheat's Avatar
bucwheat
Helped me when Techron wouldn't.
Old Jul 20, 2009 | 11:57 AM
10U 99's Avatar
10U 99
St. Jude Donor '08-'09
I've had better luck with Seafoam than Techron. One can every 4th fill up and the problem has not returned.
