Headlight
Old Jun 27, 2009 | 10:41 PM
shaggyboiler's Avatar
shaggyboiler
Default Headlight
I've had a problem for a while now. Every so often when i turn on my headlights they don't pop up. If I pull the switch you can tell that the brights kick on.
I'm thinking its the swithc stalk that is the problem. Cause once in a while when this happens if I jiggle the stalk or something the lights then pop up. Its not the motors of the headlights cause the come up just fine when they work.
anyone else seen this problem and if so what was the fix? I can order a new stalk but its like $175 and I wanted to make sure it was that before I bought it.
Shane
Old Jun 27, 2009 | 10:56 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Stock lights? No HIDs?
Old Jun 27, 2009 | 10:59 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Can you verify if the lows come on? If they do, you problem may be a faulty headlight module. This is the small black box in the passenger side headlight cove. This is what controls the headlight lifting motors.
If you can can operate all your other lights (parking, turn signal etc) with your multifunction switch, I'd suggest looking into the headlight module.
Old Jun 27, 2009 | 11:11 PM
shaggyboiler
Stock lights.
Lows do not come one when this happens. I've manually raised the lights and turn them on when this has happened and lights do not come on.
All other functions of the stalk seem to work just fine.
Shane
Old Jun 27, 2009 | 11:47 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
see if you can trigger the low beams directly with a 12v(+) feed directly to the underhood fuses. Each bulb gets it's own fuse. Then test the headlight motor fuses (again each one gets it's own fuse)
Old Jun 28, 2009 | 09:19 AM
shaggyboiler
Just run a wire and touch the fuse?
Old Jun 28, 2009 | 09:56 AM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
yes.
Old Jul 4, 2009 | 02:00 PM
shaggyboiler
so is it fuse 3 and 4?
What is the process to test this correctly? Just wire with fuse out or with fuse in? Lights turned on or off? Car on or off?
Shane
Old Jul 4, 2009 | 03:03 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I think the OP is correct in that its the headlamp switch. If he's wiggling it and they come up, then he's found the problem. There is a cheaper place to get the exact switch. Feel free to PM me if you want it. I can't post it because they are not a forum vendor.
Old Jul 4, 2009 | 03:14 PM
dgrant3830's Avatar
dgrant3830
PM received and replied too
Old Jul 4, 2009 | 03:17 PM
dgrant3830's Avatar
dgrant3830
FYI, typically when the lamps are on but not up, then the first thing would be the headlamp controller. However, the switch is what sends the command to tell the headlamp controller to raise the lights. Lots of interfacing with the BCM too.
To Headlight
